Quench question.
Quench question.
Does desired quench distance change with compression? Does a 9 to 1 eninge require the same quench as a 16 to 1?
FORDMUD- Posts : 290
Re: Quench question.
Provided you have an effective quench distance, compression ratio in-and-of-itself is not a deal changer in the quench distance.
Paul
Paul
Short block is together piston is .017 in the hole. I would rather run a stock type gasket, mainly because of the stories I read about cometics leaking on a less than perfectly machined surface.
» I HAVE MSD QUESTION
» LUNATI custom solid roller cam ./SOLD
» 4.6 question
» Cam question...
» 4.6 question
» Cam question...
