Eagle 4340 crank
Mark O'Neal
tconnection
Eagle 4340 crank Empty Eagle 4340 crank
Post  tconnection May 27th 2011, 9:28 pm
I'm about to buy a new eagle 4340 4.500 stroke internally balanced crank and would like to know if somebody can tell about how much mallory was added to their's if any at all.
tconnection
Eagle 4340 crank Empty Re: Eagle 4340 crank
Post  Mark O'Neal May 27th 2011, 11:38 pm
Unless you're running bricks, you shouldn't need any.
Mark O'Neal
Post  '65 T-BOLT May 27th 2011, 11:44 pm
Mark O'Neal wrote:Unless you're running bricks, you shouldn't need any.
bricks?..I have cinder blocks!
'65 T-BOLT
'65 T-BOLT
Post  tconnection May 28th 2011, 1:23 am
Bricks and blocks, Are yall talking about pistons?
tconnection
Post  res0rli9 May 28th 2011, 1:53 am
yep-er Smile
Post  '65 T-BOLT May 28th 2011, 2:07 am
bricks/blocks = TRW pistons
'65 T-BOLT
'65 T-BOLT
Post  BigDave65 May 28th 2011, 10:31 am
I just put one in a 521 with GRP aluminum rods and Venolia pistons and didn't have to use any mallory. On the other hand all the tolerances were on the high side and it was a pain in the butt getting bearing clearances right. I had to use .001 OS bearings in all the rods and about half the mains. The thrust bearing surface was about .003-,004 too narrow. Check it close when you get it.
BigDave65
BigDave65
Post  tconnection May 28th 2011, 9:21 pm
New pistons came in today. Diamond #40726 wieghing in at 636gr. Is this weight considered a brick or block?
tconnection
Post  richter69 May 28th 2011, 10:05 pm
I cant speak for the Eagle but my 4.3 Scat Adney had to grind the counter weights down to get enough weight off to balance it, 6.8 Scat H beam rod and a 580 gram Diamond.
Post  tconnection May 28th 2011, 11:26 pm
That sounds mighty technical and expensive. To get weight off it seems like drilling in certain spots would do it, but i don't know. Hope eagle dont give me a hard time.
Its just that i have an externally balanced eagle that's been balanced with 608gr pistons but now i have 636gr pistons. That's a 28gr differance. Trying to figure out whether to have this crank rebalanced or sale it and get another one that would be internally balanced.
tconnection
Post  richter69 May 28th 2011, 11:29 pm
He balanced the unit as well, lots cheaper to grind off material than to add mallory.
