750 double pump, manual secondaries, adjustable jets
750 double pump, manual secondaries, adjustable jets  Empty 750 double pump, manual secondaries, adjustable jets
Post  frank13 May 28th 2011, 5:24 pm
ok , so i picked up a 750 holley, with percy adjustable jets, carb is rebuild, clean and in great shape.
so i need to pick a "jet" size to start with. what is a good starting point jet wise for a mld 460 with wieand stealth intake, 600 lift cam, manual trans.
also, any recommendations on needle setting, and a close setting for the floats, before i try to fire this up
frank13
frank13
http://www.frankskinkracing.com
750 double pump, manual secondaries, adjustable jets  Empty Re: 750 double pump, manual secondaries, adjustable jets
Post  zbob May 29th 2011, 5:22 pm
72 to 76 primaries....78 secondaries
zbob
Post  frank13 May 29th 2011, 5:33 pm
bob. the higher the number jet the leaner or richer?
frank13
frank13
Post  reeseracing23 May 29th 2011, 6:08 pm
the higher the number the richer
reeseracing23
reeseracing23
