A460's makin some power
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: A460's makin some power
Larry Williams wrote:bruno wrote:HIS ENGINE IS FOR SALE ........ GOING TO A NITROUS SETUP![]()
he never mentioned that on saturday. thats a shame he is at the top of points too
he emailed me thtis morning
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
138 wrote:did he give a reason?...
just wanted to move up in the class ......
JET BOAT BOB
bruno- Moderator
wayde just posted the picture of the matco tool box he won its the width of his trailer. That plus a few thousand dollars. and he wants to give it up. lol
Larry Williams- Posts: 469
well I will say that motor is worth more at this point than if he starts losing with it....
138- Posts: 1584
i wish i had the beans to purchase the top end
JET BOAT BOB
bruno- Moderator
IDT Premier block
-Bryant light weight billet crank
-GRP 2000 pro series aluminum rods
-King main and rod bearings
-Ross digitize pistons and CNC domes
-Moroso custom aluminum oil pan
-Trickflow A-460 heads with custom titanium valves,alloy seats,psi valve springs,mainly titanium retainers,hardened locks
-Trickflow A-460 4500 intake
- Jesel custom rocker arms
- Jesel front drive kit with distributer
- roller cam bearings
- Comp cams custom grind solid roller cam-shaft
- Isky BBF .904 roller lifters
- Total seal custom piston rings
- BHJ lifter bore bushing's
- ATI balancer
- Danny bee thrust plate with double torrington bearing's
- Mainly 7/16 push rods
- 4 stage moroso dry sump system
- Moroso dry sump tank
- Moroso 4 vane vacume pump
- Meziere BBF water pump
- MSD flying magnet crank trigger
- BES sheet metal valve covers
- Dale cubic CFM 4500 carb with cnc spacer
This brand new setup only has 35 passes has been 8.22 @169.87 mph has been 174.66 mph on a 29.5 tire @3270 pounds.
also will sell converter with motor
-8'' Neil chance all aluminum billet converter bolt together with 3 billet stators.
- ATI balancer
138- Posts: 1584
Page 3 of 3 •
1, 2, 3
Page 3 of 3
