Dyno sheet for the 641" deal with a few pics..
Page 3 of 3 Previous  1, 2, 3
Re: Dyno sheet for the 641" deal with a few pics..
Post  LivermoreDave on September 14th 2011, 7:33 am
David that is a nice looking engine as well impressive numbers from your engine. I too must commend you on the effort of testing fuels, nozzle location and such.
Now, first let me say, I'm not a person with knowledge of such adventures as yours, I know very little relative to "hands-on" performance, but I do have a bit to add (comment) about the injector location and as you mentioned the fuel disturbing the air flow.
Several years ago Charlie allowed me to travel with him to Jeff Jones shop in Indiana. I was amazed at the opportunity to the "feel-free" attitude Mr. Jones offered Charlie and myself to look around un-escorted. Similar as I was when Charlie and I visited you at your former employer! Mr Jones explained to Charlie and myself when I asked of the injectors located into the cylinder head protruding into the intake valve pocket (bowl). He explained as you mentioned after switching from methanol to gasoline, the volume of methanol it takes to provide the proper air/fuel mix "cluttered" the ports ability to retain air flow when injected high in the intake. Therefore a nozzle was inserted at the beginning of the intake simply for low speed operation and delivered a small portion (%) of the total volume of fuel. The larger (% of volume) was delivered into the cylinder head nozzle.This approach offered 50 extra horsepower to Mr. Jones' application.
Another note as a few have mentioned, the height of the nozzle location. And again, I'm just asking, it seems the nozzle at a lower point would offer a bit more direct spray into the intake valve bowl, although that runner is very straight, I'm just wondering which would work the best in an application such as yours. Does the higher location of the nozzle offer more torque or is it simply a starting point?
Thanks for allowing me to ramble.
Best regards,
Dave.
LivermoreDave
Post  David Willingham on September 14th 2011, 9:56 am
Dave, I welcome all this discussion! I am in this for fun and the love of all things mechanical. I do want to say that I don't care anymore about the gas vs alky deal anymore because it causes nothing but an argument. It's just a fuel and I can run either with nothing more than a program change as long as I can keep the engine cool. I may add a radiator and run water thru the heads so I can run Q16, M5, and regualar meth and see how I like all of them. Then I'm going to run whatever I feel like is the quickest when I need to run quick, the cheapest when I'm broke, and the most consistent when I need consistency. I have no preferences and am just playing around to have fun anyway. Now that that's out of the way, on to the good stuff....
As far as nozzle placement goes, I look to folks that know more than I do and that is why the Holmes intake and the high nozzle placement. I didn't know the intake was such a bad deal until it was too late to get it swapped before the dyno. The intake is wrong and I think that is one of the reasons it's down on power. I also think the nozzles need to be as close to the head as possible, if only one set is used. The reason one person wanted them high was to cool the charge, but I think it cost power due to air displacement. This person still thinks they need to be up there, but he is now alone in his opinion. I think I will get around to try nozzles in the head someday and if I do, the upper nozzles will be as high as possible. They will be all EFI and controlled with this new MFI computer, which was modifed recently to allow any percentage of fuel to go to either stage of injectors. I can make the upper injectors flow whatever I want and the lowers whatever I want. I can start out with either stage and ramp in the other stage if I want. I also can trim any individual injector if I need to.The ignition works the same way. I can tailor the timing for each cylinder if there is ever the need.
Anyway, all I need now is the biz to pick up so I have more funds to play with. First order of business is to get a better intake on there to get the peak up to 72-7500 as I think the truck needs all the top end charge it can get to fight the aero problem it's going to encounter at 140+. Lem suggested I may want to get a new block so I can run water and I think I will do that next year.
David Willingham
Post  LETHAL_DOSE on September 14th 2011, 12:10 pm
Is there a proper placement for the down nozzles in the head? Is there someone on here that can drill and tap the heads at the proper angle?
LETHAL_DOSE
Post  David Willingham on September 14th 2011, 2:31 pm
Dave Bamber in Missouri can do it and there is a guy that Charlie may know of that does. His name is Tom Tomolion(??). I am going to try my own when I get time. I think they are to be about 1" above the seat and aim the fuel to spray thru the gap of the intake valve & seat. Dave Bamber did a C head deal years ago that made about 80-90 hp more than mine with down nozzles.
Also want to add that you may have to weld a sleeve in the head to seal up the water jacket. The heat from that may draw the seat and cause some issues. That is why i haven't done mine yet. I have to be prepared to deal with re-cutting the valve seat and make sure the seat pocket doesn't get messed up.
Last edited by David Willingham on September 15th 2011, 9:40 am; edited 1 time in total
David Willingham
Post  cool40 on September 14th 2011, 8:33 pm
great info here guys! i have a question kinda on topic, injector hat placement play any part in this? i have a spacer/adapter on my holmes intake now for the hat and plan to use the tfs short intake on my next build and did'nt know if a flat plate would work as good as anything or if i could build a spacer without hurting anything.i dont have a top for it yet and wanted to keep the same height as the holmes on my 526.any ideas? Very Happy
Post  LivermoreDave on September 14th 2011, 8:58 pm
Dave, your doing great. With your knowledge of modern day electronics and application, I have the utmost faith you will prevail.
A bit of good reading by Mr.Duttweiler in an issue of Hot Rod Magazine.
In a perfect world, nozzle location should be as parallel to the airflow stream as possible. The nozzle angle in relation to the airflow stream is termed the "intercept angle." According to Strader, the intercept angle should "not be more than 45 degrees, although it can be less." Maintaining the proper intercept angle generally helps low-speed driveability and may also improve performance throughout the engine's operating band. The lower the inlet airspeed at idle, the more critical it is to maintain the ideal intercept angle. Idle vacuum correlates well with inlet airspeed-if you have 14-18 inches Hg of vacuum at idle as read on a vacuum gauge, maintaining the proper intercept angle is not as much of an issue in terms of driveability, although there still could be some emissions ramifications.
Two Duttweiler sheetmetal intakes: A 1,600hp Buick V-6 high-rpm drag-race motor responded well to a high injector location (left). Compared with the manifold in the big photo at right, Duttweiler 's previous-generation Chevy V-8 intake (above right) had 1/4-inch longer runners and lower-mounted injectors. The reason for the change was improved fuel atomization at 10,000 rpm.So much for injector angle-what about injector placement? Should it be closer to the valve (downstream, near the cylinder head) or closer to the air meter (upstream, toward the top of the inlet runner)? It depends on the engine and application. A stocker is primarily concerned with idle quality, low emissions, fuel mileage, and engine-compartment packaging constraints. On a stocker, fuel-injector capacity (rated in lb/hr) is low (compared with a race engine), while inlet-runner velocity and low-speed vacuum are high. The small-capacity nozzle develops a good spray pattern that disperses uniformly within the incoming air stream. With good atomization, the nozzle can be located downstream, close to the valve. Small injectors don't have a lot of fuel to waste, so targeting the spray toward the back side of the valve ensures that the available fuel is used most efficiently. On the other hand, in theory, high-idle vacuum generated by mild stock engines permits placing the injector farther upstream without significant low-speed driveability degradation. In the end, OEM-style downstream injector placement simplifies system packaging and makes it easier to mount the fuel rails.
Everything changes with really large injectors (over 96 lb/hr). High-capacity injectors generate a relatively poor spray pattern with a large fuel-droplet size. As Duttweiler puts it: "You're practically just spraying raw liquid. If you put a big injector too close to the valve, there's not enough time for the fuel to mix with the air." Large injectors would most likely be used in large-displacement or high-rpm engines with lumpy cams. High rpm translates into less time between injector firing pulses, lumpy cams generate poor vacuum, and the typically large-volume inlet runners needed to feed all those cubes generally mean lower air velocity downstairs. Obviously, all this adversely affects proper fuel atomization. Moving the injector farther away from the valve allows more time for the air/fuel to atomize properly and remain in suspension when air velocity comes up at high rpm. This should improve peak power but-because of poor low-rpm velocity-at the expense of idle quality (there's no free lunch).
Looking at some real-world examples, Strader reports that on a 1,000hp engine, the injectors were originally located 7 inches back from the valves. Doubling this distance to 14 inches was worth 50 hp on top, a 5 percent gain-but "it wouldn't idle below 1,600 rpm." For an even more extreme example, consider the injector placement on today's 15,000-rpm Formula I engines. The injectors, wiring harness, and fuel-distribution rails are located topside, even inside the manifold plenum area, so they can maintain the proper intercept angle.
In the real world, mass-produced aftermarket cast-aluminum manifolds have the bosses added as an afterthought to a preexisting design. The placement is more for convenience than for best engineering practice-the available packaging architecture (including fuel-rail mounting and clearance) to a large extent dictates the nozzle location. A decent compromise for a hot-rod engine is to locate the nozzle about 1-2 inches upstream from the manifold flange to give atomization a chance, positioning the fuel rail at the best angle you can get away with and still package the harness and fuel rails. As Duttweiler puts it: "If you aim the injector more toward the valve, the fuel rail usually hits the plenum" on a converted classic V-8 carburetor-style intake. Note that at the OEM level, the trend on today's new-tech V-8 engine designs is to make them wider than a similar-displacement, old-school, classic engine. The included valve angle in some of the new late-models is nearly straight up and down in relation to the bore. That means the runners are also near vertical, which in turn allows mounting the injectors more vertically to provide room for the fuel rails and wiring harness while still maintaining a good intercept angle to the runner.
Duttweiler Performance
Saticoy, CA
805/647-5732
EFI University
Murrieta, CA
Read more: http://www.hotrod.com/pitstop/hrdp_0704_pitstop_fuel_injector_location/#ixzz1Xywbtxyh
LivermoreDave
Post  LETHAL_DOSE on September 15th 2011, 9:03 am
I did not even think about Tommy T. he does a lot with truck pull engines. I would not need the sleeve, my heads are solid, and does not have water jackets. Right now we have to run carbs, but this is a rule change year and there has been a lot of talk about fuel injection. If it passes I will probably be looking at switching.
LETHAL_DOSE
Post  David Willingham on September 16th 2011, 12:02 pm
Cool40, I don't think the hat location matters much. The Holmes has a shallow plenum and the TFS has a deep plenum. A flat plate on the TFS will work fine. I have a flat plate on the Holmes, but I radiused it very heavy to make the air curve under it to reach the corners runners. It seemed to do ok on the dyno. I don't know about the tall spacer to make the hat sit in the same location. I don't think it will matter with injection. I will have the same problem when I go to a shorter intake. I thought about using a throttle body and duct the air in from the grille and use a solid hood.
David Willingham
Post  bruno on March 24th 2012, 4:07 am
David any updates???
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  David Willingham on March 24th 2012, 5:40 pm
Not much on the engine. That will be a 2012-2013 winter project after the truck and driver have proven themselves on the track. I haven't worked on it in 4-5 months because of trying to get the biz back to making money. The last thing I was working on was the wiring. I wanted to get it running and moving around and then finish all the loose ends and get it painted. Here are some pics as it sits collecting dust.
David Willingham
Post  norm on March 25th 2012, 7:10 am
how do you like that battery? i have been thinking about getting one.
norm
Post  David Willingham on March 25th 2012, 12:12 pm
I haven't tried it yet, so I don't know if it will even start it or not. I would like to use two small lithium 12v batts and start on 24v to spin the fuel pump faster. 12v spins the engine over at 140 rpm and the pump never really builds and pressure.
David Willingham
crank trigger
Post  10SHOTS on March 26th 2012, 9:29 am
what brand of crank trigger setup is that ?
10SHOTS
Post  David Willingham on March 26th 2012, 9:43 am
It's made by me. It's just a 36-tooth wheel with one tooth missing. The MFI computer uses it and the cam sensor to keep track of where everything is for the fuel injection and ignition. With this I can control the timing and fuel for each cylinder. The MSD coil was on there for the dyno only. It has 8 coils now mounted just under the spark plugs.
David Willingham
Post  dtimmer on April 17th 2012, 1:45 pm
Nice clean build! Keep up the good work!
dtimmer
