best 60' time ? 10.5
Post  jc10000rpm on August 16th 2011, 8:16 pm
what kind of 60' times are achieved in a fox body ride with 10.5 tires ?? naturally aspirated
jc10000rpm
Re: best 60' time ? 10.5
Post  Barney on August 16th 2011, 8:45 pm
1.2s - 1.3s
Barney
View user profile http://www.hdraracingseries.com
Post  jc10000rpm on August 16th 2011, 9:13 pm
Barney, what kind of et's, and is it naturally aspirated ?
jc10000rpm
Post  Larry Williams on August 16th 2011, 9:23 pm
sbf n/a 9.76 1.33
Larry Williams
Post  Barney on August 16th 2011, 10:38 pm
jc10000rpm wrote:Barney, what kind of et's, and is it naturally aspirated ?
All of the NMRA H/S, P/S, and F/S guys are N/A 10.5 tire cars so that should give you a pretty good idea of whats possible.
Barney
Post  bruno on August 17th 2011, 5:47 am
3200 lbs with a 3055s i went a best of a 1.31 with the set of 3062 i went 1.30 n/a , which to me it doesnt make any sense i thought with the taller slick i would lose some in the 60' department
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  BOSS 429 on August 17th 2011, 9:58 am
bruno wrote:3200 lbs with a 3055s i went a best of a 1.31 with the set of 3062 i went 1.30 n/a , which to me it doesnt make any sense i thought with the taller slick i would lose some in the 60' department
the taller the tire the bigger the contact patch. = better hook
Post  badcoupe on August 17th 2011, 2:37 pm
@ 3340 #,s i go 1.26 stock style suspension n/a on hoosier 10.5 not W,s and its a street car cheers and its a 3 speed stock th-400
badcoupe
Post  bbf-falcon on August 17th 2011, 3:20 pm
jc10000rpm wrote:what kind of 60' times are achieved in a fox body ride with 10.5 tires ?? naturally aspirated
That Question really can't be answered correctly w/o knowing,HP,Tranny(c4/c6/2 speed glide),and rear gear ratio. A low geared 3 3peed will usually out short time a glide.
Post  IDT-572 on August 17th 2011, 4:31 pm
1.26 60 ft 3000 lb N/A 28X10.5 ET DRAG
Post  jc10000rpm on August 18th 2011, 5:52 am
Blake, whats the stall on your converter?
jc10000rpm
Post  IDT-572 on August 18th 2011, 8:02 am
Old engine 5400 the new one is 6100
