A460 cylinder head question
Page 3 of 3 Previous  1, 2, 3
Re: A460 cylinder head question
Post  cool40 on August 29th 2011, 9:35 pm
with a big shot of "hose"who needs a big ugly dome? afro
Post  Lem Evans on August 29th 2011, 9:42 pm
I do not see much flow while the valves are in that BIG plunge cut.
Blake...I am not picking on the pistons design......just what a guy has to do to get big compression.
Post  138 on August 29th 2011, 9:53 pm
how much comp?...
138
Post  cool40 on August 29th 2011, 9:55 pm
138 wrote:how much comp?...
all i can get. Very Happy
Post  rmcomprandy on August 30th 2011, 8:58 am
IDT-572 wrote:
Lem Evans wrote:I just wonder how ugly a dome would be that would service a 100 cc chamber...and give large comp. ratio?
About 19cc less ugly than a 119 cc chambered BBC dome would look like................ Razz
The STOCK PRODUCTION dome on an L88 Chevrolet piston is 48 cc's.
The intake valve and hindered airflow are only in that piston dome pocket from about 10 degrees BTDC to about 20 degrees ATDC; all below .250" of opening valve lift.
Post  cool40 on August 30th 2011, 8:48 pm
good thing these heads kick ass in the mid numbers! lol!
Post  bruno on August 30th 2011, 9:12 pm
would you mind post your flow #s and what cam are you using Cool ?
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  cool40 on August 30th 2011, 9:50 pm
bruno wrote:would you mind post your flow #s and what cam are you using Cool ?
these#'s were on a 4.5 bore,thats big as they had. Rolling Eyes
int.
.200=176
.300=241
.400=321
.500=400
.600=452
.700=472
.800=486
.900=498
ex.
.200=153
.300=204
.400=246
.500=302
.600=334
.700=348
.800=359
.900=368
ex is w/o a pipe.
Post  cool40 on August 30th 2011, 10:01 pm
the cam is a B.F.Evans monday morning special. Wink it's mild.i may try a Snake oil blend too.
Post  dfree383 on August 31st 2011, 10:48 am
Thats still alot of Ugly !!!! cheers
Post  rmcomprandy on August 31st 2011, 9:57 pm
A Big Block Chevy can get a bit more than 15/1 compression with a 598 however, it WILL usually make more power with only slightly over 14/1 compression ratio. Can you guess why...? LOL
Post  138 on August 31st 2011, 10:07 pm
why?
138
Post  lghting94 on September 1st 2011, 7:22 am
Less Dome
lghting94
