Nitrous problems ,car will not pick up
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: Nitrous problems ,car will not pick up
whatbumper wrote:sounds to me like the cam is not ideal.
The cam is not a nitrous cam but my cam grinder says the car will slow down with only a 250 shot with a nitrous cam. if i could get a cam that would pick me up a tenth on motor with my set up i would buy it .i just dont feel its possible
10SHOTS- Posts: 159
I just know no matter how much nitrous I threw on my last nitrous motor it would only pick up about 180hp so that is what we jetted it at. Yours just sounded familiar.
whatbumper- Posts: 1762
whatbumper wrote:I just know no matter how much nitrous I threw on my last nitrous motor it would only pick up about 180hp so that is what we jetted it at. Yours just sounded familiar.
You saying you was using a motor cam and that was happening ?
10SHOTS- Posts: 159
Yes. I had a NA cam
10SHOTS wrote:whatbumper wrote:sounds to me like the cam is not ideal.
have you talekd with Lem yet ?
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
bruno wrote:10SHOTS wrote:whatbumper wrote:sounds to me like the cam is not ideal.
not yet , think i should ?
10SHOTS- Posts: 159
big shot plate
so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 85 fuel and 95 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts,need a different converter. i think im going to stop at this point with jets
10SHOTS- Posts: 159
10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s
cool , now you are on the right track
JET BOAT BOB
bruno- Moderator
"10SHOTS",Question?,you said that when you went back to the track you changed jets from 90n 80f and ran 5.61. Then changed to 95f and 85n jets ???,and went a 5.56?,Congrats on a real nice pass! THANKS,MAVMAN.10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
Last edited by 1970 ford maverick on November 14th 2011, 4:19 pm; edited 1 time in total
1970 ford maverick- Posts: 93
When I can't pick my car up, I talekd to Lem. He tells me I need to exercise and learn to spell.
Curt- Posts: 1680
"10SHOTS",Question for you,you went faster with more Fuel than Nos?,Thanks,MAVMAN 95FUEL and 85NOS ?10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
1970 ford maverick wrote:"10SHOTS",Question for you,you went faster with more Fuel than Nos?,Thanks,MAVMAN 95FUEL and 85NOS ?10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
Sorry , meant 95 Nos and 85 fuel , thats a 275 shot on the big shot jet map
10SHOTS- Posts: 159
Thanks"10SHOTS" I have a similar build and run about the same #s with a bigshot plate. Thanks for sharing the info,MAVMAN10SHOTS wrote:1970 ford maverick wrote:"10SHOTS",Question for you,you went faster with more Fuel than Nos?,Thanks,MAVMAN 95FUEL and 85NOS ?10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
1970 ford maverick wrote:Thanks"10SHOTS" I have a similar build and run about the same #s with a bigshot plate. Thanks for sharing the info,MAVMAN10SHOTS wrote:1970 ford maverick wrote:"10SHOTS",Question for you,you went faster with more Fuel than Nos?,Thanks,MAVMAN 95FUEL and 85NOS ?10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
The new jet map for the big shot plate is much better, look into it. you 95 nos 85 fuel pull the engine timing down to 22 degrees , i run sonoco 116 maximal fuel. #10 ngk plugs . If i could buy a new converter i think a could run in the low 40s
10SHOTS- Posts: 159
Page 2 of 2 •
1, 2
Page 2 of 2
