Boost vs Cubes vs The Budget
Page 2 of 2 Previous  1, 2
Re: Boost vs Cubes vs The Budget
Post  Curt on Tue 22 Nov - 16:53
torkair wrote:
I would like to know why you feel cubes would be better than boost. I'm not disagreeing with you that it is possible I just want to know why, I need as much info as I can get and I feel that you have more than enough to back it up.
On a side note, I've been looking at how much abuse a set of stock connecting rods can take before they become a liability. If they can hold past 750 hp then I don't see any reason to change them but if there is even the slightest hesitation then forged H beams will be added to the built without question.
Edit: Also, depending on cost vs. benefit I may just have the crank offset ground for some of the other forged connecting rod options and grab a few cubes that way while reducing bearing speed at the connecting rod.
It's pretty simple, look at the cost, the packaging, maintenance and which would be more dependable in a racing application.
Post  torkair on Thu 24 Nov - 0:44
After a bit of poking around the stroker route is definitely the more cost effective route to take, there is no extra plumbing or excessive engine heat and there is also the fact that I wouldn't need to add other electronic components to the system just so I could get a good tune on the thing. With that being said I have the 2 different blocks to work with, the D9TE (from what I have read here) is externally balanced and has longer cylinder skirts (as well as a slightly taller deck), meanwhile the D1VE block is internally balanced and has a slightly shorter deck, so which block should I go with?
I am considering a 4.15" stroke combo right now but seeing as I haven't gone out and bought a rotating assembly yet I may end up changing my mind on this as well.
torkair
Post  Curt on Sun 27 Nov - 10:57
Either block will serve your purpose.
Post  torkair on Wed 30 Nov - 2:14
I figure I will go with the D1VE block first, from there stuff a 4.15 stroker kit in it, bolt on the D3VE heads after the ports have been cleaned up a tad bit and port matched to the Victor. Now should I go 6.7" or 6.8" rods and once I pick a rod length what pistons will I want in order to achieve a 9.5:1 CR with the D3 heads? And the last bit would be cam selection, I'll be running a stick shift (T56) and 3.50 rear gears in a 72 Gran Torino which I hope to have a full interior in.
torkair
Post  Northwest outlaw on Thu 1 Dec - 13:59
If you change your mind im still around just dont get on the comp much you can call anytime and ask about turbo stuff..208-512-4907
Northwest outlaw
Post  stanggt on Thu 1 Dec - 16:54
i prefer both big cubes and turboooossss Twisted Evil I agree that stroker is more cost effective, I have been battling that same subject for awile now and just said screw it, going to do both. Car just wont be out for about a year as I put it all together. just have fun with it.
stanggt
Post  jrocco on Fri 2 Dec - 8:27
The main problem I found when researching turbos on a Big Block is that there is a lot of TECH available for 1200 to 1800 HP big block turbos but there is miniscule TECH available for 750 HP to 900 HP big block turbos.
Most of the dealers you will talk to will want to relate to small block turbo applications and you will get wildly different opinions on turbo sizing.
jrocco
