Intake manifold question
I have a mild built 460 in my truck has an edelbrock performer now , i plan to replace the cam to a little bigger in the future this in a 4x4 , has dove heads .. I am wondering if i can replace this intake with a weiand 8021 and use the performer on another truck i have to replace the stock intake.
Wondering if this intake will work with my dove heads were it is for the bigger port cj scj heads, will i have to match the heads?
Will i see any performance gains over the performer or not worth the swap?
Worth swapping the stock intake with the performer or not worth it in a stock motor heavy 4x4? Stock intake do just fine?
I can get the weiand cheap if it's worth the hassle.
Or should i not bother with this intake and get the 8012 for the dove heads?
Thanks for any help have a good one
77ford- Posts : 26
Re: Intake manifold question
Not sure what mild is but I swapped my 8012 out for a victor on my 472 and picked up 3 tenths+ in the 1/4 mile. My deal has ported big valve doves and a .615/.635 solid flat tappet cam.
My guess is the 8012 will be an improvement over the performer, not sure about the 8021 since the ports are bigger than the doves.
mike
mike
f250mike- Posts : 628
f250mike wrote:Not sure what mild is but I swapped my 8012 out for a victor on my 472 and picked up 3 tenths+ in the 1/4 mile. My deal has ported big valve doves and a .615/.635 solid flat tappet cam.
mike
Mike what compression is your 472 ?
I am running a 466 with a 614 hyd flat tappet cam and running big valve ported doves with the 8012 and a 950 .
Do you think I would benefit from a vic. intake and a 1050 ?
whitefield- Posts : 2243
whitefield wrote:f250mike wrote:Not sure what mild is but I swapped my 8012 out for a victor on my 472 and picked up 3 tenths+ in the 1/4 mile. My deal has ported big valve doves and a .615/.635 solid flat tappet cam.
mike
My 472 is right around 12.5:1 compression
From my experiences last year Yes you would benefit.
I wish I had a 4500 victor and 1050 to try!
f250mike wrote:whitefield wrote:f250mike wrote:Not sure what mild is but I swapped my 8012 out for a victor on my 472 and picked up 3 tenths+ in the 1/4 mile. My deal has ported big valve doves and a .615/.635 solid flat tappet cam.
mike
Thanks ! mine is 13.5:1 comp with 110 lobe sep and 268 duration at .050 on the cam
» intake manifold question????
» just another sillya$$ intake manifold question
» Intake manifold design ~vs~ Intake air temp.
» intake manifold
» intake manifold
