BIG BLOCK FORD HORSEPOWER CHART INFO gathered by DJOHAGIN
Post  Admin on August 6th 2009, 1:05 pm
Foreword
Before diving into the horsepower charts, a few items need to be clarified first. This is for 460 Ford motors with 4.36-4.44-inch bores and 3.85-inch stroke. These charts are for new members, either just getting into engines or coming from a different motor and wanting to know the particulars about building a 460, and for seasoned Ford 460 users wanting to know how to attain a certain horsepower from their combo. It is not a pump gas only list. It is designed to give the best overall performance for a given hp range.
A brief note on detonation. If you build a motor to the ragged edge of pump gas, and it detonates, you lose horsepower and you will harm the motor. It is better to sacrifice a little power (4% per point) and use less compression. If you are determined to use high compression, use race gas. It is cheaper in the long run than to harm your engine with detonation. Octane requirements have been noted in the builds.
Basic Suggestions
The intake system
It can not be stressed enough how important the carburetor is to the build. It will determine how the vehicle runs, not only at WOT, but at all the other speeds as well. A box stock Holley Double Pumper (DP) is set from the factory rich. People often complain of poor gas mileage from the DPs because they use them on their street vehicles straight out of the box. The idle and cruising circuits are very rich, and it takes a professional carburetor tuner to get the DPs set-up properly for the street. Not only for street use, but racing use also needs the carburetor to be set-up properly. The money spent on a professional carburetor tuner pays for itself, especially with the price of gas nowadays.
Cylinder heads
This is the area where you will have, or have not, the horsepower you’re seeking.
A good thread for information on the cylinder heads used in these build-ups and other heads can be found here:
http://460ford.com/viewtopic.php?t=18321
At every horsepower level, the cylinder head should be purchased from a professional cylinder head shop/porter. There is power to be found in doing a correct valve job even at the lowest of hp levels.
Furthermore, the TFS heads and P51 are mass produced items. A professional can get them "dialed-in". Do not think because you paid X amount of dollars that the head is perfect. Sometimes, not always, they need a little touching up for them to flow like they should out of the box, a lap job for the valve seal, etc.
Shortblock updated info
A word on basic machining. The basic part recommendations in each horsepower level increases as rpm rises. It is rpm, and not horsepower that requires the better parts. The time spent at the higher rpms also affects part selection. When in doubt, it never hurts to upgrade parts. The parts suggested at each build level will be able handle the rpm with good machining.
Good machining starts with making sure all parts are sound. All steel parts should be magnaflux crack tested, and all aluminum parts with zyglo. Every part should be checked, even new parts, to make sure they have correct measurements. If you find measurements to be off, have them corrected. Even though machining in it itself does not add a significant amount of power between the best job and a poor job, the life of the engine can be affected greatly. The higher the rpm, the more critical and costly the machining becomes, due to the machinist having to mock up multiple times, setting up his equipment to get the machining “spot on”, and checking and rechecking engine measurements. Be aware also that aftermarket “race” components often require “fitting” to make them work. They typically do not just bolt-on.
On 400 to 550 hp builds, it is prudent to find a good machinist/engine builder. Past the 550 hp mark, it is best not only to find a good machinist/engine builder, but one who is familiar with building 460s. There are minor things that can make or break the combo beyond 550 hp.
The stock crank, 2-bolt mains, and factory bolts are good to the 675-700 horsepower build which after the block should be 4-bolted. It is rpm again, for the need to 4-bolt. Anytime rpm exceeds 7500 rpm, aluminum rods should be considered, as cap walk starts to show up after that rpm with steel rods.
Paul Kane’s website on oiling mods:
http://www.highflowdynamics.com/
Quench
There is more power than just raising the compression by using quench. Here is a quote from Scott Johnson and Paul Kane on the subject of the importance of quench and engine performance. In all the engine builds, this is factored in.
“Quench is the distance between the flat portion of the cylinder head deck and the top of the piston. The early BBF's set the piston about .010" below deck at TDC. Combined with a head gasket of about .040" thick this made for a quench distance of about .050". The later 460's set the piston even further below deck at TDC to further reduce static C/R with a resulting quench distance of some.065" which is really marginal.
The reason quench is important? As the piston approaches TDC the air fuel mixture in that area is violently forced into the chamber proper and serves to: rehomogenize the mixture in the chamber and cool the chamber resulting in greater detonation tolerance for a given static compression ratio. The name is derived from the fact that the small crevice area there serves to quench the flame front.
A quench distance greater than .060" loses much of the effectiveness of the design. I set most of my combos at Deck height for higher RPM use and about set the piston about .005" out of the hole for lower RPM use. Tight quench makes more torque for a given static C/R plain and simple. 7 to 10 pound feet for every .010" you close the quench distance is nothing to sneeze at.
Remember that at speed the piston and con rod stretch and the actual running distance is even closer. The higher the rpm window of operation the greater the amount of stretch. The trick is to have the piston almost kissing the head at max RPM so that the violent shock wave imparts a lot of additional mixture motion in the chamber when the flame front is in its early stages. Tight quench combos have faster mean flame front rates than non quench combos and need less ignition timing to make best power.
This is the reason I avoid using Sealed-Power pistons, or any piston for that matter, that has a short compression height which leaves the piston sometimes as much as .035" down the hole at TDC in the later blocks.”
“Just want to add that the quench area of the combustion chamber must be tight clearanced enough (as outlined above) so that the negligible air/fuel mixture does not ignite in this area.
When the quench distance is inadequate/too far open, the air/fuel mixture ignites in this area....hence, NO QUENCH.”
Exhaust system
It is important to use a free flowing muffler in all the builds. Flow- Masters do not flow enough. Any muffler were you can pick it up and look thru it, without barbs or such protruding into the airflow will be a good flowing one. If noise is a concern, then a termination box should be built and then mufflers. You are striving for no back pressure.
Adding a stroker kit
Some have asked about a horsepower chart for stroker kits. Some of the most common are:
4.39 bore x 4.15 stroke = 502 cubic inches
4.39 bore x 4.3 stroke = 520 cubic inches
4.39 bore x 4.5 stroke = 545 cubic inches
By adding a stroker crankshaft, the following occurs:
1) For every 50 cubic inches added, the rpm at which torque and horsepower peak at will drop about 600 rpm. So, if your 460 horsepower peaks at 6000 rpm, a 545 will peak at 5000 rpm. This assumes not changing anything else in the engine combo.
2) If you wish to maintain the same horsepower and torque peaks when you increase the stroke, you need to add between 12 to 16 degrees of additional intake duration for every 50 cubic inches added in displacement. Respectively, exhaust will have to be increased also.
3) The amount of torque below the torque peak, and at peak, will increase. This is a good thing, especially for street cars.
4) The larger the engine, the faster it will pull rpm. The weight of the rotating assembly is almost the same on all strokes, from a 460 to the 545 assembly, but as you increase the stroke, the engine now has more displacement pushing that assembly.
5) If you keep the same cylinder heads on the larger motor, you need to add overlap by using a tighter lobe separation, usually 1 to 2 degrees for every additional 50 cubic inches, until you get to 270 degrees @ .050" lift. Above 270 @ .050" duration, you need to bring lobe separation wider to limit overlap that is inherent after that duration. BSFC numbers go up needlessly with too much overlap.
The tighter lobe separation angle adds the necessary overlap to feed the additional inches, however, it does close the intake valve earlier. The horsepower peak numbers will be similar, but will occur at a slightly lower rpm with the tighter LSA. It is usually good not to advance the cam as much as usual.
If your compression ratio is "on the edge" running on pump gas, it may be inapproopriate to tighten the LSA because it increases lower rpm cylinder pressures. The tight LSA adds low and mid range torque because of the lower end cylinder pressures, but may not be needed if the vehicle combo is traction limited. As an example, a street vechicle only running on street tires.
6) Peak horsepower will increase slightly.
Special Note
In regards to this chart, for every listed horsepower level, there is at least 10 different combos to get that same power. The builds outlined will get you the horsepower listed, but they are not the only way. Every individual's combo requires its own unique build. Some combos may need a lower profile manifold, some solid lifter cam only, and/or it needs certain parts to qualify for a specific class.
There are only 4 different cylinder heads shown for all these builds. There are other cylinder heads that can be used for each horsepower level, and in some cases preferred, once a person learns/knows what the other heads specifications are. This link: http://460ford.com/viewtopic.php?t=18321 will help you to learn about the other cylinder heads available.
In conclusion, this chart cannot be everything to everyone. Think of this chart as just as a guide-line to get you started in the right direction.
Now for the builds:
Admin
Admin
Admin
View user profile http://460ford.heavenforum.com
Re: BIG BLOCK FORD HORSEPOWER CHART INFO gathered by DJOHAGIN
Post  Admin on August 6th 2009, 1:07 pm
275-300HP 460ci
Intake System:
Holley 600-750 vacuum secondary
Edelbrock Performer (non-RPM) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE
(No Port work. Just good 3 angle valve job.)
Intake valve size 2.08
Exhaust valve size 1.65
Stock rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5437 and Exhaust Lobe 5430
(Specs:240/250 adv., 196/206@.050, .476/.479 lift, 112 LSA)
Compression around 8.0:1
Stock crank
Stock rods
Standard volume oil pump
Stock oil pan
Exhaust:
Passenger cast-iron manifolds to dual 2.25" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
87-octane. Horsepower peak at 4,100 rpm. Keep redline to 5000 rpm.
Admin
Admin
Admin
Post  Admin on August 6th 2009, 1:08 pm
300-325HP 460ci
Intake System:
Holley 750 vacuum secondary
Edelbrock Performer (non-Rpm) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job
(315-ish/180-ish cfm @.600)
Stock rockers.
Short Block:
Intake Lobe 5430 and Exhaust Lobe 5232
(Specs:250/268 adv., 206/218@.050, .479/.493. lift, 112 LSA)
Compression around 9.0:1
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Horsepower peak at 4,500 rpm. Keep redline to 5500 rpm.
325-350HP 460ci
Intake System:
Cylinder Heads:
Stock rockers
Short Block:
(Specs:250/268 adv., 206/218@.050, .479/.493. lift, 110 LSA)
Stock crank
Stock rods
Stock oil pan
Exhaust:
1.75" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
350-375HP 460ci
Intake System:
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Keep redline to 5500 rpm.
375-400HP 460ci
Intake System:
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job and port match
Stock rockers.
Short Block:
Comp Cam XE262H Hydraulic flat tappet cam or equivalent
(Specs:262/270 adv., 218/224@.050, .513/.520, 110 LSA)
Compression around 9:0:1
Stock crank
Stock rods with good bolts
Stock oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6000 rpm.
400-425HP 460ci
Intake System:
750cfm Holley DP professionally calibrated for your application
Cylinder Heads:
D0VE heads with mild port job and chambers polished
(315ish/180-ish cfm flow @.600)
Stock rockers.
Short Block:
Compression around 9.5:1
Stock crank
Exhaust:
1 7/8" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
Admin
Admin
Admin
425-450HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished, and port match
Roller rockers.
Short Block:
Intake Lobe 5443 and Exhaust Lobe 5203
(Specs:268/280 adv., 224/230@.050, .524/.544 lift, 110 LSA)
Stock crank
Exhaust:
Summary:
450-475HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished and port match
Roller rockers.
Short Block:
Comp Cam XE274H Hydraulic flat tappet cam or equivalent
(Specs:274/286 adv., 230/236@.050, .562/.565, 110 LSA)
Stock crank
Eagle I-beam rods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6500 rpm.
475-500HP 460ci
Intake System:
750cfm Holley DP Carb professionally calibrated for your application
Cylinder Heads:
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
Roller rockers.
Short Block:
Compression at 9.8:1
Stock crank
Eagle I-beam rods
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91 octane. Keep redline to 6500 rpm.
500-525HP 460ci
Intake System:
Cylinder Heads:
TFS street heads with mild clean-up
Roller rockers.
Short Block:
Compression around 10.0:1
Stock crank
Eagle I-beam rods
Exhaust:
Summary:
525-550HP 460ci
Intake System:
850cfm Holley DP Carb professionally calibrated for your application
Cylinder Heads:
Roller rockers.
Short Block:
Comp Cam XE284H Hydraulic flat tappet cam or equivalent
(Specs:284/296 adv., 240/246@.050, .584/.588, 110 LSA)
Stock crank
Eagle I-beam
Exhaust:
Summary:
550-575HP 460ci
Intake System:
950cfm Holley DP Carb professionally calibrated for your application
Weiand Stealth Standard Port Intake Manifold
Cylinder Heads:
TFS street heads with mild clean-up and chambers polished
Roller rockers.
Short Block:
Comp Cam 34-652-5 solid flat tappet cam or equivalent
(Specs:294/304 adv., 256/266@.050, .589/.615, 108 LSA)
Compression around 10.5:1
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
91-octane. Keep redline to 7000 rpm.
Admin
Admin
Admin
Post  Admin on August 6th 2009, 1:09 pm
575-600HP 460ci
Intake System:
Edelbrock 4150 Victor Intake ported
Cylinder Heads:
TFS street heads with mild clean-up and Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR280R-10 solid roller street cam
(Specs: 280/286 adv., 242/248@.050, .657/.664 lift, 110 LSA)
Compression around 12.0:1
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,000 rpm. Keep redline to 7000 rpm.
600-625HP 460ci
Intake System:
1050 cfm Holley Dominator Carb professionally calibrated for your application
Edelbrock Dominator Victor Intake ported
Cylinder Heads:
TFS street heads with mild clean-up Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR286R-10 solid roller street cam
(Specs: 286/292 adv., 248/254@.050, .664/.671 lift, 110 LSA)
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,200 rpm. Keep redline to 7000 rpm.
625-650HP 460ci
Intake System:
1050cfm Holley Dominator Carb professionally calibrated for your application
Edelbrock Victor Dominator Intake ported
Cylinder Heads:
TFS street heads with mild clean-up with Victor port match.
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR292R-10 solid roller street cam
(Specs: 292/298 adv., 254/260@.050, .671/.678 lift, 110 LSA)
Stock crank
Scat H-beam rods with upgraded bolts
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,500 rpm. Keep redline to 7200 rpm.
650-675HP 460ci
Intake System:
1150cfm Holley Dominator Carb professionally calibrated for your application
Cylinder Heads:
TFS street heads with port job and Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam custom spec solid roller cam or equivalent
Xtreme Energy Street Rollers on intake and CR Series Rollers on Exhaust
Lobe 4879 on intake and Lobe 4682 on exhaust
(Specs:310/311 adv., 272/280@.050, .698/.683 lift, 110 LSA)
Stock crank
Block oiling mods
Deepened and fully baffled oil pan with windage tray
Exhaust:
Summary:
100-octane. Horsepower peak at 6,700 rpm. Keep redline to 7200 rpm.
675-700HP 460ci
Intake System:
Cylinder Heads:
Kaase P51 heads with mild clean-up
Roller rockers.
Stud girdle.
Short Block:
Comp Cam Custom Spec solid roller cam or equivalent
Based on the High Torque .440 for intake and RT Series for exhaust
Intake Lobe 4240 and Exhaust Lobe 5203
(Specs:284/292 adv., 256/262@.050, .761/.743 lift, 108 LSA)
Stock crank
Block oiling mods
Exhaust:
2 1/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
700-725HP 460ci
Intake System:
1250cfm Holley Dominator Carb professionally calibrated for your application
Cylinder Heads:
Kaase P51 heads with port job
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4241 and Exhaust Lobe 4135
(Specs:288/298 adv., 260/268@.050, .761/.753 lift, 108 LSA)
Stock crank with aero and lightening mods
Scat H-beam rods with upgraded rod bolts
Block oiling mods
Block 4-bolted on center 3 caps
Exhaust:
2 1/8" headers to dual 3.5" pipes with H-pipe. Good flowing 3.5" Magnaflow mufflers or equivalent.
Summary:
100-octane. Keep redline to 7500 rpm.
725-750HP 460ci
Intake System:
Cylinder Heads:
Kaase P51 heads with full race port job
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4245 and Exhaust Lobe 4137
(Specs:296/302 adv., 268/272@.050, .761/.753 lift, 108 LSA)
Custom pistons with compression around 12.5:1
Block oiling mods
Exhaust:
2 1/8" headers to dual 3.5" pipes with H-pipe. Good flowing 3.5-inch Magnaflow mufflers or equivalent.
Summary:
750-775HP 460ci
Intake System:
Edelbrock Victor Dominator Intake with full race port job and plenum mods
Cylinder Heads:
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4252 and Exhaust Lobe 4138
(Specs:300/308 adv., 272/278@.050, .761/.753 lift, 108 LSA)
Custom pistons with compression around 13.0:1
Block oiling mods
Exhaust:
Summary:
775-800HP 460ci
Intake System:
Cylinder Heads:
Roller rockers.
Stud girdle.
Short Block:
Comp Cam 34-740-9 solid roller cam or equivalent
(Specs:313/319 adv., 275/284@.050, .806/.763, 110 LSA)
Custom pistons with compression around 14.0:1
BME aluminum rods or equivalent
Block oiling mods
Deepened and full baffled oil pan with windage tray
Exhaust:
2 1/8" headers to dual 3.5 " pipes with H-pipe. Good flowing 3.5" Magnaflow mufflers or equivalent.
Summary:
110+ octane. Keep redline to 8000 rpm.
Admin
Admin
Admin
Post  res0rli9 on June 25th 2010, 11:14 pm
bowsher21 wrote: I just wanted to say thanks for taking the time to assemble the "Build list". This is the kind of information I am looking for when I start my Boss 9 build thiss fall. Until then I have a fresh short block 472" Dry sump with forged probe slight dish pistons and forged Scat rods on a stock y2 crank that is balanced.
I have a set of D0ve heads 2.19/1.76 with intake ports matched to scj intake and minor ex port work. I have a 950cfm Holly to use. Plan on racing on 1/2 mi. to 1 mile ovals.
Question? Would you kind enough to give me a base line for a build using the list of stuff I currently have?
And any guess on HP I might get?
Thank you
I thank you need to go back to proven builds or engine builds and post up a new topic..... this page is a info. page dont thank its was to be a Q/A page.
