who has the "Magic Heads"
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: who has the "Magic Heads"
richter69 wrote:honestly I dont see how an A460 is conventional........
When the rules were written it was the only thing that would compete with the chebby stuff. I have personally seen some of the new chebby edelbrock stuff go in the 525-530 range.
How about we do like some tractor pulling classes and put an RPM limit on them and give them the chip to do it.
whatbumper- Posts: 1762
so how are A heads better than BC's... I thought they were more like a C head type deal..
138- Posts: 1584
Not to mention anything chevy has like 5000 intakes, and all kinds of block options...
138- Posts: 1584
138 wrote:so how are A heads better than BC's... I thought they were more like a C head type deal..
they are winning more races
put a 500 shot on a 510 cfm a-head and put a 500 shot on a 550 cfm Big Chief which one is faster ? on a 10.5" tire
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
A ten stack thats nothing to these guys who can afford it especially when the purse is 3-4 times that.
So no one is admitting that they are running the "MAGIC HEADS" here?remember this is on a 4500 single cast intake
Larry T- Posts: 571
dry flow isn't everything..... combustion chamber, valve placement, sparkplug location, dome size, ect all come into play. its much more scientific the "My heads flow more than yours"138 wrote:That sounds a little odd... But ok.
dfree383 wrote:Conventional is a wide open term in the GM camp......
I'm aware of the rock'n conventional bbc heads. The conv. bbc heads are defined in most rule books as something not less than 23*ish valve angles. Otherwise there is not much "conventional" about them. One inch lift cams etc. are required to make them the most effective. A set is coming down this way for a bbc unpaved track vehicle. Two things you can count on......I'll get them on the flow bench & a very good set of C460 heads/manifold could be cheaper.
Magic and money both start with a "M".
Lem Evans- Posts: 4073
my IDT heads flowed 498 @ .900 on a 4.500 bore.i'd think on a 4.625 they'd do more,which IDT said 511 on 4.625. one thing i've heard the local chevy guys talk about is needing a big core cam.they spend a lot just to have a cam of much size.lol. i heard of one guy who took a chevy/olds block of some sort,aftermarket anyway,and had the headbolt holes located for EX514 heads.then he got a chevy intake,it was cast i know,and cut it all up to fit the ex heads.the chevy guys were bitchen about it having ford heads.lol.....and it wore their asses out at the truck pull too.
Like Al Neal said.......how did it run?
Like Albert Clark said.................."up your ass Cartwright, you sorry motherf-cker"..............
richter69- Posts: 8195
kinda.....richter69 wrote:Like Albert Clark said.................."up your ass Cartwright, you sorry motherf-cker"..............![]()
D. Sea- Posts: 2208
Page 2 of 2 •
1, 2
Page 2 of 2
