ladder bars....what does this tell me?
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: ladder bars....what does this tell me?
David,
When you go through the traps and "lift", a lot of the weight transfers back to the front. How does it drive then? Are you really having to steer it? If so, that's a sign of too much front end preload,,,,related to what Dave was talking about.
Charlie
Charlie
c.evans- Posts: 1507
David ,
I know this might not pertain to your situation , but it seems with my latter bar deal the more i throw at it the smoother and straighter it runs .....
later Nick
p.s. ...just spray it
later Nick
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
bruno wrote:David ,
later Nick
p.s. ...just spray it![]()
X2
richter69- Posts: 8195
Davids car is fast without spray.
Charlie....the car drives fine when I lift. It just drifts left when it's making it's best power just after the shift. I shift at 7000, (logger shows 7100 or so) and it falls back to 6400, where the meat of the power band is. The left move is not a hard left, just enough that it will get out of the groove if I don't correct it. This winter I will check the rear end squareness, get the alignment redone and then look at maybe doing some preload adjustments. After having been in a dragster for 8+ years there is a lot to re-learn about this new, totally different animal.
I might spray it sometime later guys.... It's where I want to be right now.....brackets + the ability run the 5.30 heads up classes. Next step would be to spray enough to run the 5.00 heads up. As a 1 guy operation it would be tough to spend enough to keep up with those guys.
Right now my concern is to get this thing where it's on auto-pilot. THEN I'll be able to do some finish line racing.
David Cole- BBF CONTRIBUTOR
cool40 wrote:Davids car is fast without spray.![]()
i realize his car is fast , im not saying that its slow by any means ..... his chassis is set up for gobs of juice ....thats all
JET BOAT BOB
bruno- Moderator
the bbc it had in it needed all the help it could get.lolbruno wrote:cool40 wrote:Davids car is fast without spray.![]()
Page 2 of 2 •
1, 2
Page 2 of 2
