Need some advice on a pro street truck build
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: Need some advice on a pro street truck build
The late 70 9 inch is a direct bolt in in the 80's trucks I have done a few.
bigblok2000ranger- Posts: 718
Alan, that link to Quick Performance is all you will need for any part for the rear housing and they have the best bolt on disc brake kit too. Brydon is the man when it comes to the 9". You can't beat the price, quality, service, and knowlege. I you want to put in a 4 link, it really isn't that difficult. I put mine together in about a day with some help from my neighbor. I used a common kit, and a front bracket that bolted to my frame in place of the spring hanger.
Big Daddy has spoken
Proud founder of the Truck Mafia
Definately in favor of God and guns
schmitty- Moderator
re
schmitty wrote:Alan, that link to Quick Performance is all you will need for any part for the rear housing and they have the best bolt on disc brake kit too. Brydon is the man when it comes to the 9". You can't beat the price, quality, service, and knowlege. I you want to put in a 4 link, it really isn't that difficult. I put mine together in about a day with some help from my neighbor. I used a common kit, and a front bracket that bolted to my frame in place of the spring hanger.![]()
What kit did you get? Looking on summit, the ones I see have a sub frame kit, and I'm ignorant as to how those tie into the oem frame. Also, where do I start when spec'ing the coil overs for the rear? Should I replace the oem coils up front for a set of coil overs?
HorsinAround- Posts: 161
Pinion angle
Working on setting up the new axle for the 4 link. What should I set the pinion angle at?
running cal trac they work ok in a bracket car. 60 over 460, victor, 950, 3500 stall, 700r4, 3.89, a429 heads, kb cast 10.2-1, 275x60x15 dr @3870 52 f1 11.43 @116 on motor and street driven all summer
quick 52- Posts: 254
Page 3 of 3 •
1, 2, 3
Page 3 of 3
