I need sbf crank help
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: I need sbf crank help
Call Adney I bet if anyone can do one he can and probably will at a better cost and you will know it will be right, no question about it......
the Coug- Posts: 2224
the Coug wrote:Call Adney I bet if anyone can do one he can and probably will at a better cost and you will know it will be right, no question about it......
I'll call tomorrow. I told the guy to pass on this block but he thought it was to good of a deal. With a 3.5 stroke it would be close to 380 cubic inches out of an 8.2 block. We really wanted a 3.25 or 3.4 stroke. I have never had to upsize the crank journal. We run 302 mains on our 9.2 deck cup blocks.
I guess I messed up on my math thinking a longer rod wouldn't work. Please correct me if my thinking was off.
8.2 deck
3.4 stroke
5.4 rod
~1.1 compression height
8.2 deck
3.5 stroke
5.4 rod
~1.05 compression height
Obviously dependent on a lot more factors such as gasket thickness and actuall rod used. Please, I am not a pro and do not claim to be in this department. I am an assembler who doesn't turn down much work. Lol
whatbumper- Posts: 1762
whatbumper wrote:the Coug wrote:Call Adney I bet if anyone can do one he can and probably will at a better cost and you will know it will be right, no question about it......
8.2 deck
3.4 stroke
5.4 rod
8.2 deck
3.5 stroke
5.4 rod
now that will bring you to deck height....
rmcomprandy wrote:the Coug wrote:if you use a cleveland crank in one of those blocks you have to cut the front of the crank for the gear to fit, the Cleveland has a shoulder which moves the gear out. or have the windsor stroker crank cut down to cleveland mains....
Rollmaster already offers a timing set which fits that application.
yes they do , a stock type 302 timing set . as said a stock Clev crank must be cut to W specs
other set is for W snouts in a Cleveland block
DanH- Posts: 604
whatbumper wrote:rmcomprandy wrote:Tell your customer whatever you wish however, whoever you talked with about crankshafts doesn't know what they're talking about. A Cleveland crank drops right into that block.
5.4 rods ???
ALSO:
You can get a low cost 9000 series cast steel 2.750" main Cleveland crank from SCAT in either 3.85" or 4.00" stroke with 2.100" throws.
A 2.750" Cleveland main size 4340 forged Windsor crankshaft is available "out of the box" from Scat in either 3.50", 3.75", 3.85", 4.00", 4.100" or 4.250" strokes also having a 2.100" throw diameter.
Please check post number 1. 8.2 deck block.
Scat, probe, CHP, my engine builder, Bennett, Kuntz: that's my list who don't know what they are talking about I guess.![]()
a stock 351 C crank cut down to 302 pin size , at the same time destroke the crank. off the shelf rods can be had then . can tell you , crank must be internal balanced or it will take out #1 main & have a bent crank . good deals ! can cost more sometimes
DanH- Posts: 604
DanH wrote:a stock 351 C crank cut down to 302 pin size , at the same time destroke the crank. off the shelf rods can be had then . can tell you , crank must be internal balanced or it will take out #1 main & have a bent crank . good deals ! can cost more sometimes
that's what I am trying to tell the guy. Nothing is drop in and run in this deal. in an SVO block or dart or the world products block with standard journals this is an easy deal.
5.4 rods ???
ALSO:
My mistake ... I was reading this as NINE.2" deck not an 8.2" deck.
I didn't even realize that an 8.2" deck was available with Cleveland main bearing sizes.
rmcomprandy- Posts: 1881
rmcomprandy wrote:whatbumper wrote:rmcomprandy wrote:Tell your customer whatever you wish however, whoever you talked with about crankshafts doesn't know what they're talking about. A Cleveland crank drops right into that block.
5.4 rods ???
ALSO:
I know. Damn the luck!
tell him I will take it off his hands and I just happen to have a fresh 351 C crank I can put in it......
Didn't have time to make any calls today but may have a hit on a scat crank built to this block in world product specs. 3.47 stroke
whatbumper wrote:Didn't have time to make any calls today but may have a hit on a scat crank built to this block in world product specs. 3.47 stroke
Damn and I was wanting to build a destroker to turn 9000+ rpms
In an 8.2" deck "World" block with 302 mains and 4.125" bore, I have used a Cleveland crank with reduced O.D. counterweights and cut down mains, (which isn't necessary for you), and offset ground stroke to 3.600" with Toyota rod sizes and 5.290" long SCAT rods with custom pistons for the smaller pin diameter. The CD at 1.11" was actually taller than a 347 CD at 1.09".
It was 385 inches but, looked like a 302 on the outside.
With this "World" block I wouldn't have needed to reduce the main sizes, LOL.
What about bearing spacers and a regular 302 stroker crank?
IDT-572 wrote:What about bearing spacers and a regular 302 stroker crank?
I don't know if they still make it but the old bearing kit was $599 plus the machine work to install it. I was told that it was not as simple as the chevy spacer kits.
Page 2 of 2 •
1, 2
Page 2 of 2
