460 long block -- $800.00
Post  GaryS on January 9th 2012, 2:05 pm
- D9TE short block removed from a totaled Ford PU with 40 miles on the odometer
- OEM external balanced cast crank with damper spacer, damper, and flexplate
- 'CJ' style football rods
- timing chain cover with water pump...steel OEM timing chain set
- ported C9VE heads with valves and springs to match the cam...no lifters, push rods, or rockers
- new mild flat tappet hydraulic cam...no specs
- custom rear sump pan
- intake SOLD
- distributor SOLD
Last edited by GaryS on January 11th 2012, 8:25 am; edited 2 times in total (Reason for editing : stuff sold)
GaryS
Re: 460 long block -- $800.00
Post  JR Performance Motorsport on January 11th 2012, 3:29 am
Cast pistons too right ?
View user profile http://www.e-PerformanceMarine.com
Post  GaryS on January 11th 2012, 8:03 am
Sure.
GaryS
Post  JR Performance Motorsport on January 11th 2012, 12:45 pm
GaryS wrote:Sure.
The question was does it have cast pistons ? Is $800 a new price with all the items listed as sold ?
Post  GaryS on January 11th 2012, 5:22 pm
The short block is a OEM 460 as it came from the factory...cast pistons, cast crank, just what the factory put into it. It is a 40 mile take out. The stock cam was replaced with a new mild flat tappet hydraulic cam. I do not have the cam card. Included for $800.00US:
- OEM 460 takeout from a wrecked Ford pickup with a aftermarket cam
- custom aftermarket rear sump oil pan
- mild ported C8 heads w/valves and springs
- timing chain, timing chain cover, water pump
- flex plate, balancer spacer, and balancer
Not included:
- intake, carbs, distributor, headers, water pump pulley, engine stand, brake, bench, other 460, tarp on the other 460, and anything in the picture that is not attached to the engine
Since I forgot to mention the valve covers...they are optional...if you want them, I will through them in with the deal.
If I missed something please forgive me and I will be more than happy to make it right.
Please feel free to come and look at it. If it is not what I say it is...I'll buy the gas.
GaryS
Post  GaryS on February 10th 2012, 8:42 pm
automatic block plate but pictured headers are sold
GaryS
