big cube daily driver build
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: big cube daily driver build
If the bottom end only needs Rings and Bearings thats probably a great way to go for the $$.
IMO induction and Exhaust are where you will also get a big return on the $$ Spent.
jesse wrote:maybe a better option is to rebuild it
save the money i would have spent on a stroker deal and stick some cash into
fuel system upgrades and head and intake work?
"BETTER" is a personal choice; whatever YOU think will get it closer the the end result you're looking to get.
rmcomprandy- Posts: 1882
[b]res0rli9 wrote:[quote="jbozzelle"]Look at the truck engine build Lem posted in the Engine Build section. Is your truck mass air or speed density? Both can work with aftermarket stuff, but I think the mass air stuff is easier to hop up. I may be wrong though.
Yes, Lem do you have an update on that engine, hows it run, and what kinda gas milage
I talked to the owner yesterday...he's real happy with it. 9-12 mpg he said. He also said it runs nice and cool...stock radiator and FRPP aluminium water pump.
Lem Evans- Posts: 4073
Lem Evans wrote:[b]res0rli9 wrote:[quote="jbozzelle"]Look at the truck engine build Lem posted in the Engine Build section. Is your truck mass air or speed density? Both can work with aftermarket stuff, but I think the mass air stuff is easier to hop up. I may be wrong though.
Yes, Lem do you have an update on that engine, hows it run, and what kinda gas milage![]()
I talked to the owner yesterday...he's real happy with it. 9-12 mpg he said. He also said it runs nice and cool...stock radiator and FRPP aluminium water pump. [/quote]
Thanks Lem for the update, 9-12 mpg is the same as my 466 in 76 150 crue cab got with 3:25 rear. so Id say thats good mil.
res0rli9- BBF CONTRIBUTOR
Page 2 of 2 •
1, 2
Page 2 of 2
