motor is stumbling
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: motor is stumbling
ohm the coil, and the pickup the pickup ( or stator as some call it) should be between 400 and 800, if its a stock ford unit, if its 801 or 399 its junk
i dont rem coil spec off hand
BOSS 429- Posts: 1514
im sure i got my stumble issue fixed, other then the jetting and power valve(see my other post)but i will check the coil to be be sureBOSS 429 wrote:ohm the coil, and the pickup the pickup ( or stator as some call it) should be between 400 and 800, if its a stock ford unit, if its 801 or 399 its junk
johndickjr- Posts: 566
update---pulled that high rpm intake off and got one more suited for my motor..a rpm airgap..and decided on a holley 670 avenger carb..will get this stuff on next week..i have to work this weekend..
Page 2 of 2 •
1, 2
Page 2 of 2
