TURBO FORD BUILD
Page 1 of 1 • Share •
TURBO FORD BUILD
Well you guys said you wanted to know a little about the build.
R and d is about done on the engine,car is getting mini tubed,and all the bars welded in.
in a few weeks ill do the moc up for the headers ( I have something I want to try to reduce spool time) blow off valve I want,etc
engine is a sbf,boss 302 block,alum( a ton of work in these) head,roller (solid) ,c4 car, 10.5
tire? 8.8 .
as of now theres not a wire in the car,line,int,just the windsheild.
A lot to do yet,more later
tire? 8.8 .
BOSS 429- Posts: 1514
Re: TURBO FORD BUILD
with proper cam selection and tuning, spool time is not a big deal to work with depending on turbo size. our ride with a sbf and 88 could spool after prestage. another car we help with runs a sbf with a 118 and it does take a while.
whatbumper- Posts: 1762
This will be a blow thru carb engine,With heavy modified super victor.
This car is not going to be the lightest ,and thats one of the reasons to make the turbo spool ( or engine recover) as fast as it can. Thus the reason for spending extra time on the headers. it might not even inprove, but thats what R & D is for.
It will be a few weeks before i get back on this,I'll try to get some pics up when I can.
some of the part's being used.......
PRO SYSTEMS CARB
PA RACING FRONT K MEMBER & SUP
STRANGE
BOSS 302 BLOCK
COMP CAMS ,COMPLETE VALVE TRAIN
C4 TRANS
8.8 REAR
PAINLESS SWITCH PANNEL
ATI DAMPNER
PRO SYSTEMS CARB
STRANGE
BOSS 302 BLOCK
C4 TRANS
8.8 REAR
ATI DAMPNER
