TFS Streets vs A429
Page 3 of 3 Previous  1, 2, 3
Re: TFS Streets vs A429
Post  bluef100fe on September 23rd 2009, 12:55 pm
Get R Done Dano.... Looking at what you have changed, and I agree with what others have said, you need to get a feel for what the new heads want and probably need to stretch the ole' 514's legs a little more and see what happens. Good luck. Your right though the bird is still one bad @$$ ride. Good luck...
bluef100fe
Post  56Tbird on September 24th 2009, 12:11 am
Thanks Cody,it's 12:05am and I just got the Tbird all back together. I'm not gonna fire it up until later this morning. I hope the rain stays away ..coz I'm gonna let er eat and see what happens with a lot higher shift point and turn up the leave...It's gonna go in the 50's if I have to hire a 150 lb. driver Razz Razz Very Happy
56Tbird
Post  56Tbird on September 25th 2009, 4:49 pm
Well ,I just got the tranny back in Tweety for the 2nd time this week. I rebuilt a pump and done all the mods to it. Has 205lbs of pressure with the brake ingauged at idle now!! But it pulled the pump bushing out into the seal, so I had to tear it back down and replace the bushing and seal. I took a punch and set the seal in place ,so hopefully it won't do it again. No more backing out of the stage lights hopefully cheers Now ,if it'll just quit raining so I can make some passes before BG this week drunken
56Tbird
Post  lghting94 on September 25th 2009, 4:51 pm
I am assuming 60 isnt running tonite
lghting94
Post  56Tbird on September 25th 2009, 5:04 pm
Nope ,not tonight...just called affraid
56Tbird
Post  away on October 20th 2009, 9:54 am
What happened.......Dano did you ever change headgaskets? Same thickness??
away
Post  56Tbird on October 20th 2009, 2:58 pm
Threw a rod Adrian ....messed up alot of stuff. Time for some more cubes Shocked
56Tbird
Post  D. Sea on October 20th 2009, 3:41 pm
56Tbird wrote:Threw a rod Adrian ....messed up alot of stuff. Time for some more cubes Shocked
SnakeJelly Twisted Evil
D. Sea
Post  richter69 on October 20th 2009, 3:49 pm
Jellysnake sounds better................... Very Happy
Post  jasonf on October 20th 2009, 5:02 pm
There is probably a few Boss motors for sale now that engine masters is over...... hint hint
Post  56Tbird on October 21st 2009, 10:09 am
Not in my budget range,unless they're in alot of pieces affraid
56Tbird
Post  dfree383 on October 27th 2009, 9:10 pm
Boss 9's here, get your Boss9's here, Boss 9's for sale......
Laughing
Post  GT Man on November 18th 2009, 10:09 pm
Do the a429s and the tfs have the same valve angle for the same piston releif or do the tfs have the new style scj valve and and piston releifs? thanks
GT Man
Post  richter69 on November 18th 2009, 10:13 pm
tfs is the factory angle and pierce point.
