My new 528 combo
Page 3 of 13 Previous  1, 2, 3, 4 ... 11, 12, 13  Next
Re: My new 528 combo
Post  bigblok2000ranger on February 1st 2012, 11:00 pm
I thought I wasn't doing so good taking so long to get the linkage setup but Rich reassured me that sometimes it even takes him a good amount of time get them right. I finally got the linkage arms for the carbs right today then spent about 2 1/2 hours trying to get the linkage from the intake bolts up to the cross bar correct and finally decided it needed a longer bar luckily Rich had some linkages and parts from other setups and found one that was 2 inchs longer got it all baselined from there in about 30 minutes. This engine is and will be a learning experience for me.
bigblok2000ranger
Post  BigBlockFalcon on February 2nd 2012, 1:07 pm
Good luck with your build. I also have a 525ci ford motorsports A460 heads. The new TFS intake with a Dominator carb. 14.6:1 compression with a .780 lift cam. The motor is in a 2665lbs 77 Mustang II. The best 1/8 is 5.481@126.26. The best 1/4 is 8.71@153. The best 60ft is 1.22. But consistently 1.24-1.25 60ft
Post  bigblok2000ranger on February 2nd 2012, 1:47 pm
BigBlockFalcon wrote:Good luck with your build. I also have a 525ci ford motorsports A460 heads. The new TFS intake with a Dominator carb. 14.6:1 compression with a .780 lift cam. The motor is in a 2665lbs 77 Mustang II. The best 1/8 is 5.481@126.26. The best 1/4 is 8.71@153. The best 60ft is 1.22. But consistently 1.24-1.25 60ft
What tranny are you using? Are geared more for the 1/8 or 1/4? Is it consistant? Just curious.
bigblok2000ranger
Post  BigBlockFalcon on February 2nd 2012, 1:52 pm
I'm running a glide. It's set up for 1/4 mile. On the 8.71@153 pass the 1/8 was 5.54@123. It's deadly consistent. I won the 2011 Division 2 Bracket final's with that car.
Post  bigblok2000ranger on February 2nd 2012, 2:03 pm
Thank you sounds like mine should be right where I need it.
bigblok2000ranger
Post  BigBlockFalcon on February 2nd 2012, 2:45 pm
I'm definitely interested in this build. I think you will need more compression than 14.1 and the cam will have to be .800+ lift and the duration @.050 will have to be around 300. Keep us posted. I will like to know how it turns out.
Post  bigblok2000ranger on February 2nd 2012, 3:02 pm
Oh I will, I will not post cam specs though at the engine builders request as he considers that stuff propriety info.
bigblok2000ranger
A little bling!!! LOL
Post  bigblok2000ranger on February 25th 2012, 1:10 am
Trading my 8580 dizzy and 6AL and Blaster II coil to a friend for new Crank Trigger and Crank Trigger Distributor.
Think we have my headbolts from the 523 traded for a set of head studs for my A460's. Block and rotating assembly will probably be headed to machine shop sometime this coming week.
Last edited by bigblok2000ranger on March 24th 2012, 10:53 pm; edited 1 time in total
bigblok2000ranger
Post  bruno on February 25th 2012, 8:08 am
good looking stuff , but damn clean your finger nails before you ruin a pic Razz Laughing
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  dfree383 on February 25th 2012, 9:28 am
bruno wrote:good looking stuff , but damn clean your finger nails before you ruin a pic Razz Laughing
You mister manicure now !!! Laughing Laughing Laughing
Post  BOSS 429 on February 25th 2012, 12:21 pm
lol
Post  bigblok2000ranger on February 25th 2012, 2:55 pm
LMAO! I thought they were pretty clean as is, lol
I am constantly tinkering with things and don't think I have ever been able to keep them "clean" for more than an hour or two. Honestly if I ever get the point where I don't have a project to tinker with I create one.
bigblok2000ranger
Stuff I do when I am bored lol
Post  bigblok2000ranger on February 25th 2012, 3:06 pm
Bruno here is some stuff I do when I am bored, lol
bigblok2000ranger
Post  bigblok2000ranger on February 27th 2012, 10:01 pm
Been doing some research today and it looks like a real possibility to happen, I am gonna attempt to set the world record for quickest N/A all steel Ford Ranger with this build.
bigblok2000ranger
Post  69F100 on February 28th 2012, 8:07 pm
scratch Evil or Very Mad
