Aluminum Radiator
kjett
77f150
Aluminum Radiator
Can anyone offer a recommendation on a drop in quality aluminum radiator for a '77 F150? The old stock rad is near the end of its life and clearance is tight so a drop in would work best but hoping someone can point at a brand they had success with. Thanks.
77f150- Posts : 220
Re: Aluminum Radiator
Contact Joe Mayab he can hook you up
kjett- Posts : 1169
I went to oreilly auto not to long ago and their stock replacement was an aluminum cores radiator with the plastic tanks
lghting94- Posts : 762
I put one of those in my pulling truck about 3 years ago, it has worked good and cools better than the old one did.
72puller- Posts : 105
We don't the O'Reily chain up this way, I'll look into Joe Mayab. Thank-you.
77f150- Posts : 220
This has been a great radiator for me:
http://broncograveyard.com/bronco/i-20608-bronco-aluminum-radiator-for-manual-trans-.html
Danny Cabral- Posts : 14
Danny Cabral wrote:This has been a great radiator for me:
this is the one i use,also.
norm- Posts : 257
I am sure that radiator is a great one but I would run down to your local parts store and see what they can get as a stock replacement, I believe most of them have went to the aluminum cores with plastic tanks.
Thank-you for all your help, I'm going to pick-up the #20610 Auto Trans rad from Bronco Graveyard. I have a large auxiliary tranny cooler but was going to use the cooler in the radiator to help. Do you think this is overkill or unnecessary?
77f150- Posts : 220
I believe a cooler in front of the radiator is more than sufficient and plumbing through the radiator's cooler just creates a restriction. (Looks messy too.) The Bronco Graveyard aluminum radiators are very durable and fully soldered (no epoxy). They're made by Heatex and they're high quality.77f150 wrote:I have a large auxiliary tranny cooler but was going to use the cooler in the radiator to help. Do you think this is overkill or unnecessary?
Thanks Danny!
77f150- Posts : 220
» Need A New Fox Aluminum Radiator
» Aluminum Radiator
» custom aluminum radiator
» Summit Aluminum Race Radiator & Fans - SOLD
» Trade for CJ/SCJ/PI Aluminum Valve Covers M/T SBF Black Aluminum Finned
» Aluminum Radiator
