500 inches on alcohol
Page 2 of 2 Previous  1, 2
Re: 500 inches on alcohol
Post  KY JELLY on February 22nd 2012, 3:26 pm
Yea but truck pullin works more like a dyno than drag racing .
KY JELLY
Post  56Tbird on February 22nd 2012, 3:27 pm
Ok ,Q16 it is then!! Thank you Mr.February Laughing
56Tbird
Post  rmcomprandy on February 22nd 2012, 3:29 pm
pullboy wrote:Theyn wont allow injection and if I use a tunnel ram i cant run in the street stock class but which one makes more power gas or alky?? HP tv says alcohol makes more power than gas in a 383 same motor same comp alky made more power which way should i go????single 4 bbl stock production block and heads what can we do to beat up the chevy's
It's not THAT simple.
How much fuel you NEED to pass through a single carb will be a lot dependent upon the size of the carb and the total amount oif fuel you need to make the specific horsepower.
If you run methanol LEAN then it hasn't got a chance up against Q16 in a horsepower race. When the horsepower gets up in the higher ranges, you can't get enough methanol; to pass through one carb unless you make the carb total air cfm less.
In short ... the higher the power level, the more difficult it is to get enough methanol through ONE carb in order to extract the power.
Post  KY JELLY on February 22nd 2012, 3:30 pm
I did not say that , never paint yourself into a corner mr Hobbs lol!
KY JELLY
Post  56Tbird on February 22nd 2012, 3:31 pm
I know how to paint JY Kelly Razz
56Tbird
Post  bruno on February 22nd 2012, 4:01 pm
KY JELLY wrote:Yea but truck pullin works more like a dyno than drag racing .
are you serious scratch
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  KY JELLY on February 22nd 2012, 4:29 pm
Yes sir you got xxx horsepower and it takes just a little bit to get the sled moving and a little bit of traction , if the weight was on the front of the sled at the begining it would be like applying the water brake full tilt on an engine at idle on a dyno .
There is a lot more to it than that , but you do not shift and you want wheel speed and maximum momentum and horsepower as soon as possible . Gas shines on the horsepower end simply because it burns faster and more efficiently at high rpm.
KY JELLY
Post  Lem Evans on February 22nd 2012, 5:46 pm
KY JELLY wrote:Yes sir you got xxx horsepower and it takes just a little bit to get the sled moving and a little bit of traction , if the weight was on the front of the sled at the begining it would be like applying the water brake full tilt on an engine at idle on a dyno .
It's the never ending struggle...finding a fuel that is not only efficient but popular also. Wink
Post  richter69 on February 22nd 2012, 6:43 pm
it ain't a popularity contest......... Laughing If cow piss made more power than gas or meth I'd run it.......and not give a damn what other though about it lol.
Post  Lem Evans on February 22nd 2012, 7:38 pm
I guess you missed KY's post about how 'popular' methanol was.
Post  KY JELLY on February 23rd 2012, 8:21 am
Fabio knows it will Et quicker and run cooler and more consistent with a cj head , Fabio is already popular he don't need methanol to prove it lol!
KY JELLY
