Late model 1966 Mustang advice
Tommyj466
knrclark
I'm thinking about putting a late model (87-93) 5.0 into a 66' coupe just for a daily driver. has anyone done it and do have any advice for me?
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
Re: Late model 1966 Mustang advice
We're doing that with a 65 galaxie. You need to decide on a few things going in. Will it be fuel injected or carbed. We are using a carb. The accessory drive needs to be addressed. Do you want to use a V-belt or serpentine set-up. The balancer pulleys are different late model to old. We got lucky and are using a 5.0 out of an 89 or 90 lincoln. It has two multi-rib modern style belts and the water pump is a standard rotation water pump. 5.0's in mustangs use a single belt and are reverse rotation. The Lincoln motor, which is a roller block (not all are, I swapped in a Mustang GT cam), allowed me to use an early style timing chain cover with provision for mechanical fuel pump. Otherwise, you'd need an electric pump for the carb, which I don't want on this car.
Google the 5.0 swap to early mustang and your head will swim. It's a great thing, but there are obstacles.
Good Luck
TJ
Good Luck
TJ
Tommyj466- Posts : 322
I swapped an 88 5.0 into a 66 Fairlane years ago. I would just get a complete everything if you can. I ran external walbro pump and used the factory fuel line as a return line and plumbed it into the filler neck. Everything is typical sbf as far as front sump oil pan. You will need to drill out a hole in the timing cover for the dipstick as well. I modified the stock efi harness. There is a lot of info out there and i would recommend doing it.
Below is a pic of my uncles 66 that he did.
jasonf- BBF CONTRIBUTOR
it's a cool setup for a dd.i would'a did my 68 that way but it's a 351 and has a healthy cam in it.i may someday put a fast efi on it.
Wow! Thanks guys. I had no idea it would be that involved. My theory was to buy a wreck and transplant everything. I kind of wanted fuel injection and an electric pump.
My car has the old cloth covered wiring and a generator. I wanted to swap wiring and go AC...with A/C to boot. Also, long term, disc brakes and maybe some upgraded suspension parts.
I'll keep everyone posted and please do not hesitate to comment further.
Kerry
Kerry
Great upgrade and its been done a whole lot over the years.
That would be awesome as a daily driver. Good luck with the project!
patfromjersey- BBF CONTRIBUTOR
knrclark wrote:Wow! Thanks guys. I had no idea it would be that involved. My theory was to buy a wreck and transplant everything. I kind of wanted fuel injection and an electric pump.
Kerry
Check your Vin # Kerry,the generator's were replaced by Alt's in 65. Looks to have a 66 grill though.
OK
Hey Rick, it's funny you mention that. There is a lot of weird stuff on this car. I was talking to the guy who owns that Mustang ranch a while back and he had similar concerns. The VIN# says it is a 66. My Dad ordered this car from a dealer. I suspect he just got some goodies when he was not supposed to. One of the reasons I decided to Mod the thing and not go back all original is these funny issues and it is a 66 coupe and nothing special except it belonged to my Dad since it was born. If I spend 10,000 on it it would still only be worth about 3500 at best, so, she gets upgraded and driven around and not a creampuff.
» 2011 Mustang performance test are coming out...13's from the V-6 model....WOW
» 460 waterneck
» 1966 Mustang Parts
» 1966 Mustang Pro Mod/Top Sportsman
» 1966 mustang 289 flex plate????
» 460 waterneck
