Carb'd Heads?
Carb'd Heads?
Hey guys. I am in the process of putting headers on my 1994 F250 with a 460 in it. I was looking at how small the exhaust ports are. My question is can you put DOVE's on a factory efi 460? Or any carb heads? Thanks
njstang87- Posts : 106
Re: Carb'd Heads?
The heads themself will bolt on.... Issue is the Intake and Exhaust Manifolds will not work.
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
