got my 1962 home
johndickjr
Page 1 of 2
Page 1 of 2 • 1, 2
Re: got my 1962 home
had a bad vibration , so i tore motor done, taking it to machine shop..i found a broken timing gear but car still ran, i thought the timing was acting funny when i was setting timing..and it has the wrong pistons in it, the pistons that are in it are 240 pistons and are .230 in the hole..for a whooping my binding 7-1 compression..cam starts pulling at 3000 and stops at 6000..so if i put more cam in it and some 351w pistons to get the compression up, it should run pretty dam good for a 6 banger
johndickjr- Posts : 896
I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
i was shocked that i got a 1.83 60ft ..then discovered it has 7-1 compression...with the piston ill put in it and cam, it should run 12.00IDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
johndickjr wrote:i was shocked that i got a 1.83 60ft ..then discovered it has 7-1 compression...with the piston ill put in it and cam, it should run 12.00IDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
I'm sure it will run that, I was amazed at the power the engine we did made.
took it to get balanced..crank was 25 grams off...flex-plate was trash..not sure if it was like that before or after..he got crank rods and all withing 1/2 gram..so it should be good to go
how did that work ? always wondered how a dome on a 351w will fit the inline head cause of the valve angle compared to the dome angleIDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
johndickjr wrote:how did that work ? always wondered how a dome on a 351w will fit the inline head cause of the valve angle compared to the dome angleIDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
I can't remember the exact dome height, but the volume was 5 cc and It had plenty of valve to piston clearance with a .650 lift cam and dur @ .050 around 260 on a 104 sep Trying to remember specs off the top of my head. but there close.
You can always get some custom slugs made.
dont want to spend that much , not trying to sit the world on fire, looks like dome top 351w pistons will work ..it will be between 11.5--12 compression depe nding on my cc of head mand not sure if deck has been cut..at a bare min 11.5 compared to the 7-1 it is now..heck that probally close to at least 50-75 hp..i hopedfree383 wrote:You can always get some custom slugs made.
just bought a set of trw dome pistons, will give me 11.5 compression, stay tuned,,may get new cam also
61coon wrote:Those "big block" 300's are some pretty tough engines. I'm really looking forward to hearing the results from your trip to the track this weekend.
Check this out, pretty neat article
http://www.carcraft.com/featuredvehicles/ccrp_1108_1971_ford_maverick/viewall.html
Just spotted this.. that's my chassis guy Mike Robinson... one hell of a craftsman. His old race car was a tube chassis Maverick that was absolutely gorgeous. 9.32 @ 149 with a 466 & Doug Nash Wish I was more on my camera game back when he had it..
Update--10-26-2012...redone the motor, discovered it had wrong pistons in it, .230 in the hole.. so i put early model rods in it with some trw dome 351w pistons for 11.5-1 compression..new roller rockers..new steel timing set..degreed the cam..proform 650 carb..same deal as last time, i had my hand on shifter and did not go 2 feet and hit 2nd gear..then when about 100 ft and went to 3rd..ran 13.33@94 mph 1/4 mile...and 8.30 1/8 mile.--1.87 60ft...went threw lights at 6200 rpm..next pass radiator started leaking and i put it on the trailer ..it will run low 12s once i learn not to touch the shifter
we need some pics !! Any more runs on it?
i get some pic..im going to tnt friday night , to get that low to mid 12 sec slipdfree383 wrote:we need some pics !! Any more runs on it?
went out last weekend, could not get car to stall for nothing, not even on the tranny brake..it worked fine few weeks ago..easy 4000 on brake..now at 2500 it pushes the car..so not sure whats going on there, so i foot braked it.. 1.73 60ft time and a 8.21 1/8 mile and a 13.20 1/4 mile..i pulled motor out already and have a decent 302 going back in..
Page 1 of 2 • 1, 2
» Home sweet home, Back from the chassie shop
» 62 Galaxie for sale
» 1962 Ford Fairlane 25.5 Project
» 1962 falcon front suspension
» 352 FE 1962 Ford Donated High School Auto Shop Engine
Page 1 of 2
