How much boost could you run?
I have an A460 block, Blue Thunder CJ heads and a scat forged 4.5" crank.
How much boost could you run with a 1071 before you started hurting parts? Engine would be for a burnout car seeing 6500 rpm max.
busta- Posts : 28
boost
With the proper race gas you can run easily run 20 lbs. On pump with some octane booster about 10-11 lbs. All these numbers can change with water injection, or intercooling. Using timing control is a good idea as well such as MSD's BTM unit.
blown473- Posts : 376
» Boost and efi
» eco-boost ....
» Boost and timing?
» how much boost would it take....
» It's been a long time coming!!
» eco-boost ....
» Boost and timing?
