fuel pressure regulator problem
is it possible to have a fuel reg which is meant for a pump of a higher volume? I have a regulator which i cannot get to adjust and stay adjusted to 7 psi. it always goes to around 3 psi after 15 minutes or so but i play with the reg and it comes back up for about 15 minutes.
cooter- Posts : 220
Re: fuel pressure regulator problem
get a kit for it, rebuild it
BOSS 429- Posts : 2365
what size is the return line?
Larry Williams- Posts : 884
no return line
cooter- Posts : 220
cooter wrote:no return line
I just had a pressure problem with mine and called aeromotive. I was told that with a -10 feed line I needed a -10 return to settle the fuel pressure I had a -8
Problem solved for me now.
thanx for the help
cooter- Posts : 220
» Aeroquip Fuel Pressure Regulator
» Fuel pressure keeps rising on one regulator
» BG 2 port fuel pressure regulator
» fuel pressure regulator question
» Another oil pressure problem, please help!!!
