Chuckathon: Help Chuck get back onto the Dragstrip
Page 10 of 11 Previous  1, 2, 3 ... , 9, 10, 11  Next
Re: Chuckathon: Help Chuck get back onto the Dragstrip
Post  69F100 on January 3rd 2010, 8:22 pm
Damon or Chuck can ether of you post some pics of the header collectors that blowen473 gave you I would like to see how the evac is welded in it.I need to weld one in my headers just want to make sure I am on the right track.
Thanks Jim
Post  D. Sea on January 4th 2010, 11:53 am
Not the same collectors but very similar, here's a few pictures of mine when I first put it together.
D. Sea
Post  69F100 on January 4th 2010, 5:45 pm
Thanks Damon that is what I was thinking would it be to much trouble to see what degree it is set at and post it it looks to be aroung 45* it is sitting just want it to pull good.
Thanks Jim
Post  D. Sea on January 5th 2010, 12:22 pm
Yep, they are cut at a 45 degree angle for welding into your collectors. Best place to place them is on top however that's just not possible in a Fox Body scratch
D. Sea
Post  IDT-572 on January 6th 2010, 10:57 pm
Damon
I am to lasy to read all the posts, is there a list of what Chuck will need to finish up?
Post  D. Sea on January 7th 2010, 11:53 am
IDT-572 wrote:Damon
Too much to list, I'll have to update it but here's what I have on the excel file
1 Strut type front suspension
2 Shifter Cable
3 Fuel Cell: 5 or 8 gallon Brandon Reid
4 Fuel Pressure Gage
5 Oil Pressure Accumulator & Solenoid
6 Drag Chute, release cable and handle M. Stevens donated a chute
7 Crank Case Evac System
8 Window Net
9 Two Batteries: Optima type
10 Safety Belts:
11 Oil pan & Pickup: Rear sump
12 Trans cooler: stacked w/fan & thermostat
13 Glide tail shaft housing and possibly the case. Coug
14 Wheelie Bars Steve Neville "Nevs"
15 Push-Pull On/Off battery disconnect Travis Rice
16 Header flanges - TFS Streets & 2 1/8 - 2 1/4 tubing plus collectors to make custom headers Charlie Evans
17 Fan(s) for radiator: First we need to measure radiator sent by Rick Brown
13-Nov
18 Rack and Pinion
19 Coil Over Rear Shocks
20 Wheels Front Wheels: Jon Faubion
21 Slicks 32 X 14
22 Engine Plate - Front: D. Willingham?
23 4-Link Brackets
24 3/4" LH Tap
25 Master Cylinder
26 Rear Brake Caliper Brackets - Need to get a drawing
D. Sea
Post  Nevs on January 7th 2010, 12:33 pm
D. Sea wrote:
IDT-572 wrote:Damon
2 Shifter Cable
8 Window Net
10 Safety Belts:
13-Nov
18 Rack and Pinion
21 Slicks 32 X 14
23 4-Link Brackets
24 3/4" LH Tap
25 Master Cylinder
Damon,
I can fix you up with a fuel pressure gauge as well. I've got an Autometer Sport Comp with the isolator and the hoses, etc. I'll bring it to the tech seminar if you want it. Let me know.
Post  D. Sea on January 7th 2010, 12:35 pm
Sure thing, bring it and if we can't use it, I'll send it back. That goes for all donations
Thanks guys!
D. Sea
crank case evac
Post  dr's wife racing on January 7th 2010, 4:39 pm
Do you still need one, I think I have a a new one out in the shop some where, PM me if you do and I,ll look it up. Ward
dr's wife racing
Post  69F100 on January 7th 2010, 7:11 pm
Thanks Damon for the info on the evac tube mine will have to be in the side as they are tucked tight under the cab for ground clearance
Jim
Post  D. Sea on January 8th 2010, 12:09 pm
dr's wife racing wrote:Do you still need one, I think I have a a new one out in the shop some where, PM me if you do and I,ll look it up. Ward
Ward,
Need one?
Are you guys (you and Cole) going to the tech seminar?
D. Sea
Post  69F100 on February 14th 2010, 12:09 am
any updates yet
Post  D. Sea on February 16th 2010, 3:05 pm
Snow........
Chuck said he's going to drop the rear out of the old car tomorrow.
D. Sea
Post  Maddmattmustangs on February 28th 2010, 10:44 pm
Just happened across this and figured i would ask if you guys are still taking donations?
I dont have much but i doubt i will be on the track anytime soon so maybe some of my money can go elsewhere to someone that can put it to use soon.
Maddmattmustangs
Post  D. Sea on March 1st 2010, 12:14 pm
Maddmattmustangs wrote:Just happened across this and figured i would ask if you guys are still taking donations?
Always and thanks to you and EVERYONE involved Cool
I'll shoot you a PM
D. Sea
