BBC Damper/snout on BBF
Dave C.
gordyd4
Some guys build their custom cranks with a BBC snout and double 1/4" key-ways for the added strength.
Using a Jesel belt drive, what is the preferred method of dealing with the seal?
Just machine it out for the BBC seal?
gordyd4- Posts : 145
Re: BBC Damper/snout on BBF
Seems logical to me. I know Carroll has machined out timing gears for the BBC i.d. dimension.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Use a Danny Bee and request the BBC snout pulley, problem solved. I run that on my own motor. And am doing a couple now.
Bret
Bret
Bret Powell- Posts : 133
Solid block
Sold my 800" shortblock, now I'm looking at building a nice 650" that will take a lot of boost.
Who makes an aluminum solid block for the BBF? Billet or cast.
I already talked to Carrol Carter about his cast blocks. Just want to look at all options.
Dart makes a billet block for the BB Ford. Others do to, I think LSM.
The short boss snout and even the std long snout works fine for N/A engines, even for some blown applications, but for high hp blown stuff, it's just a lot stronger to use the BBC snout.
Dave C. wrote:Why do they want a BBC snout ?
Gordy and Randy have already answered your question correctly. It is a strength thing simply based on size, meaning snout diameter. Of the big three engines, the 429-460 BB Ford is the smallest in diameter, next up is the 426 Chrysler Hemi stuff, and even bigger in diameter is the BB Chevy snout.
Charlie
c.evans wrote:Dart makes a billet block for the BB Ford. Others do to, I think LSM.
I looked on darts site and did not see any BBF blocks.
gordyd4 wrote:c.evans wrote:Dart makes a billet block for the BB Ford. Others do to, I think LSM.
Got to call them
Called Dart; no BBF billet block program.
Call Kaase then. I could have sworn that he said Dart made Bob's billet block.
Charlie
Charlie
I talked to the owner.
» Going from standard snout to boss snout crank
» Crankshaft snout
» Balancer on long snout crank
» Boss crank snout.
» BBF crank w/ chevy snout
» Crankshaft snout
» Boss crank snout.
