Going for 10.0 Frank13's New'er Build
Going for 10.0   Frank13's New'er Build Empty Going for 10.0 Frank13's New'er Build
Post  frank13 on December 9th 2012, 9:06 am
Ok so after the fastest pass at 11.90 at 119 I decided to make some changes to the car this year. Time to ditch the road race suspension, add a hotter cam, get the PI heads ported out, change intake-carb-headers, and just do a clean up on the motor.
Other goal is to get the 3440 weight with me in it and get it down to 3100lb with me in it.
Finally, the final goal is drag week 2013
Here are some before pics:
Going for 10.0   Frank13's New'er Build FranksRowbigblock
frank13
frank13
http://www.frankskinkracing.com
Going for 10.0   Frank13's New'er Build Empty Re: Going for 10.0 Frank13's New'er Build
Post  frank13 on December 9th 2012, 6:32 pm
ok time to tear the short block down just to check things out:
thrust bearing need to be replaced as it has started to shed but all in all, she is in great shape Now off to the machine shop for the block to get cleaned
Going for 10.0   Frank13's New'er Build DSCF0484
Going for 10.0   Frank13's New'er Build DSCF0487
Going for 10.0   Frank13's New'er Build DSCF0490
Going for 10.0   Frank13's New'er Build DSCF0494
Going for 10.0   Frank13's New'er Build DSCF0495
Going for 10.0   Frank13's New'er Build DSCF0498
Going for 10.0   Frank13's New'er Build DSCF0497
frank13
frank13
Post  bruno on December 9th 2012, 9:02 pm
good luck with the next build Frank !!!
http://WWW.CKRME.COM
Post  frank13 on December 9th 2012, 9:52 pm
thanks Nick
frank13
frank13
Post  quick 52 on December 9th 2012, 11:07 pm
im going to take a look at my engine to this year its been 3 years sence its been open. i'm going to try make it to drag week have gone a couple times butthe last couple year it was just to far for me go luck with the build.
quick 52
Post  Mike R on December 10th 2012, 1:07 am
Frank, how thick are your K-member spacers? It looks like your motor is sitting nice and low.
Post  frank13 on December 10th 2012, 2:54 pm
Mike R wrote:Frank, how thick are your K-member spacers? It looks like your motor is sitting nice and low.
they are two pieces of 1/2 inch alum plate
stacked so i could adjust the height.
So the crank is heading to the machine shop to see if they can fix it, scored pretty bad on the thrust surface. FML!
only damage on the engine when taking it apart!
frank13
frank13
Post  jbozzelle on December 10th 2012, 7:24 pm
You didn't check the thrust during assembly?
Post  frank13 on December 10th 2012, 7:46 pm
jbozzelle wrote:You didn't check the thrust during assembly?
I did not assemble the short block, the machine shop did.
fwiw its a stick car
frank13
frank13
