Anti-reversion plates
Anti-reversion plates Empty Anti-reversion plates
Post  Dave De on December 9th 2012, 12:17 pm
I understand the flow theory but see mixed results comments on the web.
What would I gain with my set-up? (580 cubes, victor or mafia with 1050 dominator and roller .680 lift 280/290 Dur at .050, below 7000 rpm)
I know I'm under carb'd.
Thanks,
Dave
Anti-reversion plates Empty Re: Anti-reversion plates
Post  dfree383 on December 9th 2012, 12:32 pm
What heads?
Post  Dave De on December 9th 2012, 12:47 pm
Dont know why the heads should matter as they are way down stream of the flow.
SCJ-B's with bowl work and back cut valves also P-51's will be very similar.
Post  dfree383 on December 9th 2012, 1:07 pm
What are you hoping to gain? What's the application?
Post  Lem Evans on December 9th 2012, 1:16 pm
Is this the style you speak of?
Anti-reversion plates 300-4500-rAnti-ReversionPlate-1
Post  Dave De on December 9th 2012, 1:17 pm
dfree383 wrote:What are you hoping to gain? What's the application?
Pro-street Mustang 3100 pounds 70% strip.
What am i hoping to gain? Nothing if its not worth anything or something if its worth buying the plate and using it.
Seriously is this that difficult to post an experience?
Post  Dave De on December 9th 2012, 1:19 pm
Lem Evans wrote:Is this the style you speak of?
Oh yeah
I've been thinnking about using the mafia manifold insted of that lame Victor.
Post  Lem Evans on December 9th 2012, 1:21 pm
I've seen good results with them,,,,,,,,gotta work at & near the flange to accomadate the skirts of the spacer.
Post  Lem Evans on December 9th 2012, 2:05 pm
Post  Dave De on December 9th 2012, 3:17 pm
Lem Evans wrote:I've seen good results with them,,,,,,,,gotta work at & near the flange to accomadate the skirts of the spacer.
Could this be a bolt on for the mafia manifold? Gains on my type of build?
Post  Lem Evans on December 9th 2012, 6:31 pm
Gains compared to.....no spacer, open spacer, HVH supersucker or Jomar power cone ?
Post  quick 52 on December 9th 2012, 7:52 pm
the plates i've seen work even better come with braided tie down straps at each end of the plate and a ballast tank for the trunk
quick 52
Post  dfree383 on December 9th 2012, 9:24 pm
I did see any difference on my 2009 boss 9 emc entry, using a pair on a weiand tr and a pair of 1150's.
They may help a little with drivability, but I saw no power gain to speak of in my application.
If your worried about reversion and use yours on the street a decent amount, id suggest going with a different cam.
Post  Lem Evans on December 9th 2012, 9:43 pm
Dave, he very much does have a different cam and the T.R. very much does put the valve job a long way from the booster in the carb. from what he is doing with the 4 x 1 deal. Sometimes 'we' need to forget about that masters of the universe stuff and reflect on a guy's given appication.
I in no way think that it's the answer for all.... given that 'it' may reguire 'mods' to the manifold a 'drop-on' deal like the Jomar power Cone or HVH S.S. may be a great answer for many.
Post  rmcomprandy on December 10th 2012, 1:14 am
That's amusing, to say the least ...! Laughing
Post  dfree383 on December 10th 2012, 1:21 am
Agreed.... but a smaller cam will go a long way in something being driven on the street, especially if he is concerned about reversion.
Another scenario comes to mind, is it a fix for a problem that isn't a problem?
Post  Lem Evans on December 18th 2012, 8:28 pm
I don't think Mr. DeClerk thinks he has a 'reversion' issue. I suspect he used the "R" word because QFT calls them anti-reversion plates.
The long and the short of it is that that style of spacer does make more power in a lot of applications.
Post  richter69 on December 18th 2012, 8:34 pm
Anti-reversion plates 986A8952-B712-4DB6-B837-08E68A1F764B-218-000000A9EA56395C
Post  richter69 on December 18th 2012, 8:39 pm
Anti-reversion plates 1B3D5A8F-7591-443B-A9E5-CDED2311AD71-218-000000AB46898751
Anti-reversion plates 93638AFD-780C-4C9F-A135-1982DF8BB972-218-000000ABC0D04C03
Post  Lem Evans on December 18th 2012, 8:47 pm
Where did you get those pictures of Freelander?
Fabio....he's gonna be back in the USA in 3 weeks and you may have to pay for your transgressions Evil or Very Mad
Post  richter69 on December 18th 2012, 8:52 pm
he might use "The Sword of Power" on me............ affraid
Post  c.evans on December 18th 2012, 9:00 pm
Fabio,
You've been watching way too many childrens cartoons or something Exclamation Man, I thought you worked for a living, but apparently not Exclamation Twisted Evil
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 on December 18th 2012, 9:05 pm
google is your friend....... and im off work........ Razz nothin to do in the shop im waitin on parts........
Post  dfree383 on December 18th 2012, 10:29 pm
By the power of........... sunny
Post  kjett on December 21st 2012, 10:38 am
dfree383 wrote:By the power of........... sunny
Camel toes?? farao
kjett
kjett
