Hypothetically ???
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: Hypothetically ???
Really?
All the NOS jetting charts which I begin tuning with for the plate kits are bigger on the fuel jet at 5.5psi. I realize they are fat for safety reasons and I usually end up dropping the fuel jet a few sizes and get a nice looking plug. Never tried evening them out or going smaller than the nos jet with the fuel one on the plate. I will have to test this out. Carefully...
4thHorseman- Posts: 233
I learned by spending money do not run the nos tunes or the motor rich, most failures are caused by lifted ringlands in nos motors( i lifted 8 ) this is due to fuel getting by the rings then igniting the leaner(more fuel you can burn) the less chance of this happening. I run an 8 jet spread 8 more nos than fuel and have not hurt any parts this year and won the 5.95 championship for King of the streets.org. I read alot on Steves forum on YB and Monte Smith after trashing 8 pistons and so far i have had good luck. the main thing is pull timing read plugs and keep adjusting until you have your specific tune for your motor. when you pull a plug in my motor at the end of a pass it looks like new.
studly- Posts: 462
My interest was peaked earlier about your comment.
I've been on YB on the nitrous forum for about an hour now and I am enlightened.
I was pretty happy with my run on an 85n/91f tune using a progressive. The more I read the more I realize how jacked up that factory-type tune is. Ha!
At 6psi fuel pressure, how does something like an 85n/78f tune up sound for a 225hp progressive hit?
4thHorseman wrote:"here is the 2nd pass with the plate 73/63 @ 5.5 @ 25*"
Don't want to hijack. Just interested in clarification. That's a 73N/63F jet setup in your NBS plate for your 1st stage? If so, I must be running my tune fatter than I expected. ???
I have it backwards right?
I'm running 85N/91F @ 6.5psi 28 degrees timing and ramping it in from 55% to full over a 1.5 seconds spread.
Shaving a second and adding 12mph to my na 1/4 et.
I'm running corrected 9.6@141mph with that tune on my junk.
yes that is correct ........... you need to call Steve and run your combo over with him and he can get you a baseline tune .....always ck your plugs
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
i think a true 225 hit will probbaly be a 91 nos jet and 85 fuel jet at about 5.5, but bruno is right call Steve he have been doing this stuff alot longer than most, i am getting ready to send my victor 460 intake for a fogger install, the speedtech plate i have is alright but a fogger is the good mojo.
studly- Posts: 462
4thHorseman wrote:My interest was peaked earlier about your comment.
I've been on YB on the nitrous forum for about an hour now and I am enlightened.![]()
any updates with your car??
JET BOAT BOB
bruno- Moderator
Page 2 of 2 •
1, 2
Page 2 of 2
