A429 552 BBF
+6
OldRed70
QtrWarrior
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
A429 552 BBF
This is the new engine build for the Ranger
Heads A429 ported flow numbers unknown
Intake Edlebrock Victor 4500 pad port matched to heads
RPM Crank 4.5 forged
RPM Rods H-beam 6.7
Keith Black KB 860 -.060
Block D9
Cam Doug Hebert H6C @ .050 275 INT 284 EXT Lift .708 .712 108 lob center with Chet Hebert matching springs
Comp cam Roller Lifters
Comp Billit Timing set 9 way key
Comp Cam Push Rods 3/8'' 8.45''
Dove mgf Roller Rockers
Melling HV oil pump
ATI Damper
CSR Flex Plate
1150 Dom Carb to seat everything in with then the APD 1050 Alky Carb will go on if not big enough a tolit will be in store.
Some Pics
RPM Rods H-beam 6.7
Block D9
Melling HV oil pump
ATI Damper
CSR Flex Plate
Some Pics
Re: A429 552 BBF
Jim,
Let me dig around for the flow numbers..
They have to be here somewhere..lol
QtrWarrior- Posts : 2697
Re: A429 552 BBF
nice solid build , you better hang on
Re: A429 552 BBF
Jim
Let me know when you take it to SGMP. I would like to see ou run , like Bruno said better hang on that s gonna be one amazing ride
OldRed70- Posts : 155
Re: A429 552 BBF
If you don't have a windage tray in that thing you better tear it back down and get one in it because with a stroke that big it will pick up oil from the pan ... and the heads should flow 340 in 232 ex... about normal for them...
the Coug- Posts : 3055
Re: A429 552 BBF
Thanks Mike if you have them that will be great to know how they flow but when it hits the track I believe it will let me know how good they are and how my c6
Re: A429 552 BBF
the Coug wrote:If you don't have a windage tray in that thing you better tear it back down and get one in it because with a stroke that big it will pick up oil from the pan ... and the heads should flow 340 in 232 ex... about normal for them...
Thanks for the info Coug no it don't have a windage tray I did put a low oil pressure light in this time.I didn't buy a windage tray it will be get a new pan when I do the frontend swap on it next winter.On a windage tray will it work with any pan or do you have to get one for what pan you run.This is my 1st stroker engine of any kind so I am new to what all is needed for for one.The pan has already been on a 557 with no problems turning 7200 rpms without a tray is the only reason I did not ask about a windage tray.
Re: A429 552 BBF
OldRed70 wrote:Jim
I call you when I get it ready and when I heads down that way.
Re: A429 552 BBF
Jim I just use a motorsport windage tray works fine, I have seen many times when you start getting up in the stroke the crank pulls oil from the pan, not so much on the front sump pans but way worse on the rear sumps. But it is nice cheap insurance in either case
Re: A429 552 BBF
the Coug wrote:Jim I just use a motorsport windage tray works fine, I have seen many times when you start getting up in the stroke the crank pulls oil from the pan, not so much on the front sump pans but way worse on the rear sumps. But it is nice cheap insurance in either case
I will check in on 1 my engine is still on the engine stand just recieved my push rods today and will be next weekend before I get a chance to install it with work. So no big problem to install one now might as wail go ahead and do it now and be done with it and added insurance.
Curt- Posts : 2787
Re: A429 552 BBF
Who sales a good tray FRP dont offer one any more canton and milodon has to be trimed for a stroke from what I have seen so far.
Here is some pics
Here is some pics
Re: A429 552 BBF
looking good
bigjohn2007- BBF CONTRIBUTOR
Re: A429 552 BBF
Thank was hoping to install it in the morning but old mother nature is show her face again rain and t storms so it looks like it will sit on the engine stand another week
Re: A429 552 BBF
Well just maybe next Saturday it will go in and fired up.
Re: A429 552 BBF
552 is up running truck moves under it own power once again it is alot heather than the 460 didn't get on it but eased down on it just a tad and it felt better than before.I only have 110 turbo blue in it right now not enough octane to get on it hard but I can still feel the different in power.
Re: A429 552 BBF
Congrats Jim , I know you are Excited . Now time to head to Cecil for TNT .
Re: A429 552 BBF
Got a couple more thing to do 1at change gears to 4,30 and universal joints
Re: A429 552 BBF
Let me know before you head down . Would like to see you run.
Re: A429 552 BBF
Glad to hear it's coming together Jim.
schmitty- Posts : 4538
Re: A429 552 BBF
Congrats
Re: A429 552 BBF
Thanks guys I will post some results after I make a few passes hoping to carry it in 3 weeks for some tnt passes still need to do the gear change to 4.30 ,new universal joints,and put a bigger battery wire to the starter.With this engine my starter is pulling more amps and heating the wire up some when the engine get up to temp.Starts ok when the engine is cold if the cable change don't help then I will buy a new starter I have the db starter on it now.I have never had a problem with it on the 460 starting but it don't have the compression like the 552 does.
Re: A429 552 BBF
Be sure to put a good spacer deal under that carb.
maverick- BBF CONTRIBUTOR
Re: A429 552 BBF
maverick wrote:Be sure to put a good spacer deal under that carb.
Kim I don't have room for a spacer right now until I do the frontend swap under it amd remove the windshield I got to cut some out of the cowl.I am afraid if I cut it now the windshield will crack from no support from the removing the cowl and windshiel bracing.I was looking to cut it while the engine was out but decided to wait until I do the front end change then lexan windshield.
Page 1 of 2 • 1, 2
Page 1 of 2
