1st drag radial test
+9
gmsmkr
dirt_worker
bigblok2000ranger
yellowhorse7
soupbean
13 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 1st drag radial test
on the 275 tire class could someone use the M/T ET Street tire (bias ply) that is the same size???
butterbean- Posts : 676
[quote="butterbean"]on the 275 tire class could someone use the M/T ET Street tire (bias ply) that is the same size???[/quote
To answer your question Roy.....yes they are legal.... here is my take on bias ply tires they work great on a stick car I mean really good and take a lot of the shock from the suspension but at the same time they like to really wobble on the big end I would also use a tube with them.
Now for the radial get it hot and hit it hard they like it and a lot better stability up top in the mph and work good with stick or auto it will just take a little more work with them and a stick car.
This is just my experience with them and what I have found running them on different combos.
gmsmkr- Posts : 1364
butterbean wrote:on the 275 tire class could someone use the M/T ET Street tire (bias ply) that is the same size???
if the track is radial prepped the bias tires will not work very well. I'm sure people make them work but they are not ideal at all. My MT rep says those are being discontinued anyway.
whatbumper- Posts : 3024
Not meant as a post hijack seems relevant to the posts, which brand of drag radials are the hitters running, or not running and why? More interested in track performance, than street duty as the radials already have better street manners.I have been running the M/T's but on regular slicks I have had the best hook with the Hoosiers, there are size limitations out there if you are looking for specific sizes also.
FalconEh- Posts : 1448
M/T 275/60 here and on slicks it's M/T 28-10.5 we are fixing to put a set the MH tires on a customers car and see they work I have heard good things so far
I haven't tried them I like the old style my self but I'm willing to try new stuff just haven't had the chance yet
How do yall like the new style?
gmsmkr wrote:How do yall like the new style?
As far as i'm concerned there is no other tire than the pro MT 275 or the MT 315.
Im goin out sunday to make a few hits w the truck on some new 275 MT pros.
I'm excited to see how they work on my junk.
dirt_worker- Posts : 535
keep us posted on how it does and how you like them
whatbumper wrote:gmsmkr wrote:How do yall like the new style?
This. The ones who refuse to use these are simply behind the times. The old style radials are complete garbage as compared to these new pro tires
yellowhorse7- Posts : 1382
1st pass on the radials...it started to hook just like soups initial outing...then spin like its on ice.
I got the front struts full loose...rear single adj shocks on 10 of 14. 18.5 lbs tire pressure and 4000 chip. Convertor flashes to 6000.
Leafspring and caltrac setup.
Any advice from you fellas while im still at the track?
double post...
loosen the rear shocks. single adjustable adjust the extension. you want it to extend. and move the caltracs up a hole on front. for your ride I would have it all the way up. and if you have any power taken out throw it all back in.
^^^^this you want it to move and give it all you can , probably let a little air out also ....
Is it knocking the tires off before or after 60'?
We loosened the rear shocks and lowered the tires to 17lbs. It hooked great and went 1.42 60ft. Thats a person best to date by .10!
Im sold on the radials now!
3rd and final pass I lowered the leave to 3000 just to see how it responded and it went 1.48 60'.
Next time out im hittin it w 5000 and lookin for a 1.3 somethin 60ft.
Got some solid info now to baseline from. Really happy w the results today w my heavy ol street truck!
Nice, very
We spend many hours looking for something new, when you get on to something and are finding success it brings back any excitement that may have floundered. Well done keep us posted.
whatbumper wrote:Good job
You Too ! 16 min response time to I am at the track post.
FalconEh wrote:whatbumper wrote:Good job
I have to stay on the phone always. Email, forums, & calls. Thats how you get and keep customers. Remember I feed my family doing this it's not just a hobby.
Plus, we broke a ring gear in X car last night and just lost in quarters in mx235. Now it's time to load up and get the heck out of here.
dirt_worker wrote:We loosened the rear shocks and lowered the tires to 17lbs. It hooked great and went 1.42 60ft. Thats a person best to date by .10!
I'm late to the party as usual.....
is it possible to hit the pros too hard? if so, what would the symptoms of that be? by no means do I think that's what I'm doing. I'm just wanting to know how much harder I can hit them then I am now?
dirt_worker wrote:is it possible to hit the pros too hard? if so, what would the symptoms of that be? by no means do I think that's what I'm doing. I'm just wanting to know how much harder I can hit them then I am now?
you're hitting them too hard when you smoke them before you move. other than that keep hitting them harder.
whatbumper wrote:dirt_worker wrote:is it possible to hit the pros too hard? if so, what would the symptoms of that be? by no means do I think that's what I'm doing. I'm just wanting to know how much harder I can hit them then I am now?
Thanks Justin. ..thats exactly the kind of answer I was hoping for!
» cant get any damn info , ive put on yellow bullet ect ... the diff between a drag radial,radial slick,bias slick pros and cons
» New M/T drag radial.....295/55/15
» 89 drag radial mustang
» Pro drag radial class ADRL
» 1989 drag radial coupe
Page 2 of 3
