ANY HP/TQ GUESSES,IDEA ???/
ANY HP/TQ GUESSES,IDEA ???/ Empty ANY HP/TQ GUESSES,IDEA ???/
Post  FORDIN on November 16th 2013, 1:45 pm
I WOULD LIKE SOME HONEST GUESSING HERE....HERE IT IS. A SCJ 4 BOLT DOVE BLOCK .030 OVER,4.3 FORGED SCAT CRANK,EAGLE 6.8 RODS,PROBE FORGED PISTONS. ITS HAS BEEN LINE HONED, ZERO DECK FLAT TOPS. THE HEADS ARE D3 PORTED BY SCOTTYS SPECS,2.25 I,1.76 E. I THINK THEY ARE AROUND 330/180..NOT SURE. THE CAM IS A 280H MAGNUM(230/.530 LIFT). IT HAS COMP PUSHRODS, GUIDEPLATES. SCORPION 1.7 ROCKERS. ARP HEAD,MAIN ,ETC. ITS BALANCED SFI BALANCER AND FLEXPLATE. HAS A PERFORMER RPM AIR GAP INTAKE,BIGS 950 HOLLEY DP. SCOTTYS DURASPARK,MSD 6AL BOX. HEADERS,3 INCH EXHAUST W/CROSSOVER. HERE IS AN IDEA OF WHAT IT HAS DONE TO HELP . IT IS IN A 6800 LB 1978 FORD SWB 4X4 D60 FRONT 10.25 REAR. 5.13 GEARS. 44X19.50X17 BOGGERS. WHEEL TIRES WEIGH 196LBS EA. C6 203/205 DOUBLER MILD STALL(AROUND1700). I WENT TO TTC(TOP TRUCK) AS ALTERNATE I MADE A FULL PULL UP THEIR HILL TOWING 36,000+ LBS.(ON YOU TUBE) ALSO IN THE SAND DRAGS IT RUNS 5.7-6 SECONDS IN 300 FT. WELL THATS ABOUT ALL THE HELP I CAN BE.....ANY IDEAS???THANKS FOR YOUR INPUT/HELP........BRAD.
FORDIN
FORDIN
ANY HP/TQ GUESSES,IDEA ???/ Empty Re: ANY HP/TQ GUESSES,IDEA ???/
Post  460bronco on November 16th 2013, 10:51 pm
Guess I'll throw a dart... 490hp and 630tq
460bronco
460bronco
Post  dfree383 on November 16th 2013, 11:37 pm
Around 500hp, but it will have good torque.
Post  supervel45 on November 25th 2013, 4:04 am
How does that Comp 280 cam sound in that big motor, much lope at idle? That 630 torque guess, seems plausable, to me. I won't even guess at the horsepower.
