D0VE screw in studs
D0VE screw in studs
Need a good used set of 7/16" screw in rocker arm studs for D0/C8 heads, I have 3/8" nuts.
Thanks.
GT300TD- BBF CONTRIBUTOR
studs
did you find any studs? I have the factory ones off my doves if you need them
capncruncher1965- Posts : 131
Re: D0VE screw in studs
capncruncher1965 wrote:did you find any studs? I have the factory ones off my doves if you need them
PM sent
Thanks.
DanH- Posts : 1081
Thanks.
Don't really matter, they don't work anymore anyway. They just hang around...always in the way .
GT300TD wrote:DanH wrote:better check your balls, your nuts may be to small.GT300TD wrote:
Thanks.
LOL
I got correct on the thread size once. I thought they were 3/8' upper thread on the stud for the round ball fulcums. 7/16 fine thread for the upper.
DanH- Posts : 1081
» Should he screw it?
» getting the oil filter threaded insert out of the block for oiling mods...
» Don't screw with Grandma..........!
» Screw in soft plugs
» Whipple 510 Twin Screw
