My 598 TFS A-headed build
+16
butterbean
old blue
soupbean
bigjohn2007
460pulling
ProStreetFairlane
dirt_worker
61coon
Copperhead
20 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Re: My 598 TFS A-headed build
991.2 hp @ 6,300
991.9 hp @ 6,900
There is realy not a pronounced 'peak'.....looks flat to me.
991.9 hp @ 6,900
What kind of converter/stall you going to put in there?
windsor- Posts : 1167
windsor wrote:What kind of converter/stall you going to put in there?
I'm going to try to utilize my Ultimate Converter Concept 9" unit that I used on my previous 557 engine. I might have to have it adjusted to suit this set-up, but I want to try it first and get a baseline before I send it in.
Heck,.....If I'm lucky it might be good to go. Time will tell.
Copperhead- Posts : 492
Lem Evans wrote:so, where did it stall?
It's been 2+ years since I ran the truck, BUT,.... "IF" I remember right,...
It would flash to around 5500 on the T-Brake.
Cool...hope the conv works out nicely.
Would love to see lower rpm torque numbers.
Very nice!! Unported heads too. Are they 18 bolt heads?
68formalGT- Posts : 864
So are these the same heads you had on the old 557 that Seth originally built?
Ah. Yes, recall now that was sold a second time. Thanks, Lem.
Nowindsor wrote:So are these the same heads you had on the old 557 that Seth originally built?
68formalGT wrote:Are they 18 bolt heads?
All of the compoments in this engine are brand new,.....with the exception of the oil pan.
The heads are indeed the 18-bolt version.
Part # 5451T802-M87
Vacuum pump or no?
windsor wrote:Vacuum pump or no?
No
Nice build hope everything work out for you..............
bigjohn2007- BBF CONTRIBUTOR
Engine is finally in the truck & running.
https://www.facebook.com/photo.php?v=685226608192847
Now I just need to get it to the track and get some seat time.
SHWEEEEEEEEEEEEEEEEEET!
Let's see under the hood.
https://www.facebook.com/photo.php?v=685257324856442
Awesome.
maverick- BBF CONTRIBUTOR
Glad to see the truck is alive once again!
soupbean- Posts : 637
man that some nice numbers, what was the cam specs
old blue- Posts : 124
Update... Have you been to the track yet..
res0rli9- BBF CONTRIBUTOR
X2^^^^^what he said^^^^^
butterbean- Posts : 676
res0rli9 wrote:Update... Have you been to the track yet..
Oh yeah,.......
5.89 in the 1/8th,......... 9.33 in the 1/4
» 572 A-460 headed build
» Looking to build a 501 A-headed engine for X275
» Here's my SCJ headed 521 build...
» 572 P-51 headed build...
» My 598 TFS A-headed build 2.0
Page 1 of 3
