fuel pressure regulator question
fuel pressure regulator question Empty fuel pressure regulator question
Post  cooter on March 6th 2014, 11:01 pm
What happens if you do not hook a vacuum line to the fuel pressure regulator? Will it still work?
cooter
fuel pressure regulator question Empty Re: fuel pressure regulator question
Post  rmcomprandy on March 6th 2014, 11:12 pm
cooter wrote:What happens if you do not hook a vacuum line to the fuel pressure regulator? Will it still work?
It will work but, bot the way it is supposed to work.
The vacuum line on a fuel pressure regular is there to always keep the fuel pressure drop across a fuel injector the same because one side of the injector sees manifold vacuum.
With a carburetor, that line should simply be atmospheric pressure.
Post  cooter on March 10th 2014, 9:49 am
thanks randy
cooter
