USED COMP CAMS SFT CAM AND HOWARDS LIFTERS
Post  BigRigTech on March 26th 2014, 1:54 pm
Used solid flat tappet camshaft, 5 dyno pulls and forty 1/4 mile passes on it. It comes with Howard's EDM lifters bagged and tagged for each lobe. The lifters were $200 alone. The cam was broken in on the dyno. Asking $200 for the cam and lifters as a kit. Switching heads and pistons, going with a larger cam. Will trade this and towards a 1050 domi or Jomar stud girdles and pay cash in the difference. I have an offy Single plane intake in another ad to that could be used in trade.
Cam Style:Mechanical flat tappet
Basic Operating RPM Range:2,500-6,500
Intake Duration at 050 inch Lift:248
Exhaust Duration at 050 inch Lift:248
Duration at 050 inch Lift:248 int./248 exh.
Advertised Intake Duration:294
Advertised Exhaust Duration:294
Advertised Duration:294 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.605 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.605 in.
Valve Lift with Factory Rocker Arm Ratio:0.605 int./0.605 exh.
Lobe Separation (degrees):110
Intake Valve Lash:0.022 in.
Exhaust Valve Lash:0.022 in.
Computer-Controlled Compatible:No
Grind Number:FF 294S-10
BigRigTech
BigRigTech
Re: USED COMP CAMS SFT CAM AND HOWARDS LIFTERS
Post  BigRigTech on March 29th 2014, 5:14 pm
BigRigTech
BigRigTech
Post  BigRigTech on April 15th 2014, 8:26 am
BUMP. Make an offer. Wink
BigRigTech
BigRigTech
