Short turn radius tip to stabilize dove heads with 2.25 valve at high lifts.
We found while playing with my doves that by just slightly adding a flat spot, I mean slightly going up to the creast increased .550 and up numbers while making less turbulent and kept increasing flow to the 1inch mark instead of flattening out around .600 . They were flowed on a consertative flow bench around 360 at 700. Flow was probed to be very strong on the cylinder side. Ported them just like my TFS heads I did except for the short turn. It was flowed on a 4.40 cyl. which I believe would of been better on a 4.60 hole. They flowed 8 cfm less then my ported streets on this bench. Anyone else noticed or tried this approach? Will see if my buddie car pics up with these heads over good ported ones and same valves..,ED
ED468- Posts : 199
Re: Short turn radius tip to stabilize dove heads with 2.25 valve at high lifts.
ED468 wrote:We found while playing with my doves that by just slightly adding a flat spot, I mean slightly going up to the creast increased .550 and up numbers while making less turbulent and kept increasing flow to the 1inch mark instead of flattening out around .600 . They were flowed on a consertative flow bench around 360 at 700. Flow was probed to be very strong on the cylinder side. Ported them just like my TFS heads I did except for the short turn. It was flowed on a 4.40 cyl. which I believe would of been better on a 4.60 hole. They flowed 8 cfm less then my ported streets on this bench. Anyone else noticed or tried this approach? Will see if my buddie car pics up with these heads over good ported ones and same valves..,ED
YES ... it does help high valve lifts but, it hurts .300", .400" & .500" so it depends upon if you value maximum flow over the whole curve.
That is determined mostly by how the heads are to be used and the camshaft in the engine.
head porting
Yes the head was ported for a high lift solid roller with higher rpm in mind with a 1150 dominator. Small tire car at his track cant use the torque he has
ED468- Posts : 199
» forged .030 over pistons 460 stock length rod and stroke . for dove heads high compression
» Looking for short valve covers for c460 heads
» Dove heads valve size
» Short Moroso Valve Cover on P51
» Big valve ported dove heads ,solid roller camshaft ..$2000 with new studs you pay shipping
