BBF - 429
NorCal66Galaxie
Page 1 of 2
Page 1 of 2 • 1, 2
Re: BBF - 429
[quote="NorCal66Galaxie"][quote="NorCal66Galaxie"]
Do I run a hyd. Flat tappet or a SFT?
bbf-falcon wrote:On the Cheap? Use your heads w/mild porting good valve job w/bigger valves,good flat tappet w/roller rockers,performer (dual plane intake for street), 750/850 Holley,2500 stall and 370/391 gear and a shift kit C6.AND make it a .030 w/460 crank. You don't necessarily NEED forged pistons for street driving,
NorCal66Galaxie- Posts : 13
Re: BBF - 429
Either one,I would prefer solid,but thats just me.
Re: BBF - 429
NorCal66Galaxie wrote:NorCal66Galaxie wrote:bbf-falcon wrote:On the Cheap? Use your heads w/mild porting good valve job w/bigger valves,good flat tappet w/roller rockers,performer (dual plane intake for street), 750/850 Holley,2500 stall and 370/391 gear and a shift kit C6.AND make it a .030 w/460 crank. You don't necessarily NEED forged pistons for street driving,
Awesome right in line with what I was thinking over the weekend, must be on the right track. thank for the help
What cam do you suggest I run with? I was thinking running a Weiand stealth intake and a Holley...thoughts? I had read that the Edlebrocks were hard to tune correctly...
NOT a good choice in my opinion for an engine which will spend most of its time at Part Throttles and not WOT. The area inside that intake manifold is cavernous and is slow to react for good throttle transient opperation although it will make good power at Wide Open Throttle.
I would suggest a Torquer II for the most power but, an "Air Gap' for best average power at all throttle openings.
As far as camshaft ... a good, well matched hydraulic will get the job done however, other things come into play needing compromises such as Power Brake vacuum needed and such. Something custom would be best.
Last edited by rmcomprandy on July 18th 2014, 9:49 am; edited 1 time in total (Reason for editing : spelling, punctuation.)
Re: BBF - 429
rmcomprandy wrote:NorCal66Galaxie wrote:NorCal66Galaxie wrote:bbf-falcon wrote:On the Cheap? Use your heads w/mild porting good valve job w/bigger valves,good flat tappet w/roller rockers,performer (dual plane intake for street), 750/850 Holley,2500 stall and 370/391 gear and a shift kit C6.AND make it a .030 w/460 crank. You don't necessarily NEED forged pistons for street driving,
Ok I'll check into a cam then and see what intake suits it best..
How about Holley 850? Double pumper? Vacuum or mechanical?
Re: BBF - 429
Just call Randy,he is very knowledgeable in bbf combos. he will help you in the right direction.
The finest in custom engine building for all venues ...!
Selling those Parts & Supplies from companies I use ... 1 (586)909-1591 ... fax 1 (586)771-2930
CUSTOM ground camshafts
Carburetor modifications for specific applications
CNC porting
CNC porting
Re: BBF - 429
bbf-falcon wrote:Just call Randy,he is very knowledgeable in bbf combos. he will help you in the right direction.
CNC porting
Re: BBF - 429
What does all of that mean?
Re: BBF - 429
Answered my next question and I'm really excited to start this build...this forum is really helpful. There's a wealth of info here. I'm looking forward to start posting pics of the build...I'm busy for the month of August the plan is to start immediately after.
Re: BBF - 429
Every time I read through the forums here I come up with more questions...
On my heads...C9VE-A's
What size intake/exhaust valves?
Planning on bronze valve guides & hardened seats
5 angle valve job
Milled (if needed)
Should I pay to have them ported or can I do this myself? I hear the exhaust floors are thin :/
Are there any secrets to making these heads flow better?
5 angle valve job
Milled (if needed)
Re: BBF - 429
What I meant on the valve question was....what size should I increase to?
Re: BBF - 429
You can get to the power level you want by doing a good bowl blend, open your bowl up to the bottom diameter cut of your valve job all the way down to the bottom of the bowl.
Smooth the short side and leave the shape the same do not remove any material other than what it takes to smooth it out.
Page 1 of 2 • 1, 2
Page 1 of 2
