14-71 Mooneyham blower
Post  IDT-572 on September 18th 2014, 10:13 am
Posting this for a friend, just freshened $3000.00. Can get pics if you want.
Re: 14-71 Mooneyham blower
Post  Dave C. on September 18th 2014, 12:23 pm
Is it anywhere near the right size for a 588?
Dave C.
Post  IDT-572 on September 18th 2014, 12:27 pm
Just depends on the boost pressure your wanting to run and rpm your turning the engine.
I would think it would be on the small side for a 588 turning above 6500 and building 15-18 lb boost.
It would work by over driving it , but I don't think it would be optimum (intake heat may be a problem).
Maybe someone with real time experience would chime in.
Post  738drvr on September 18th 2014, 1:18 pm
If it's anodized you could run alcohol or E85 and not have a heat issue at moderate boost levels. Check clearances and let her eat. Mine was overdriven and worked good on alcohol. Made the switch to E85 and looks to work the same. Engine out now for a block that can take the boost. Remember, combination is everything.
Post  IDT-572 on September 18th 2014, 3:06 pm
Selling just blower and snout. I was told that it would run on a 588 if the compression was 11:1 or better and ran at about 20% over.
I have more pictures if you like. This is a very nice piece.
Thanks for the info Frank................. Cool
Post  738drvr on September 18th 2014, 9:14 pm
You bet buddy. That is a nice piece. Would work great on just about any 385.
Post  Branch engineering on September 19th 2014, 12:35 am
Can you shoot pics to 9515918982 thanks
Branch engineering
Post  IDT-572 on September 19th 2014, 9:04 am
Branch engineering wrote:Can you shoot pics to 9515918982 thanks
Sent.
Post  bronco911 on October 3rd 2014, 7:52 pm
Ok, so what other major parts would be needed to run this piece? Any ideas? Ignorant to the blower world, but it is appearing to be the next step everyone is taking and this looks like it may be the way/price point to start with (depending on what else is needed)
Thanks!!
bronco911
bronco911
