460 engine failure 800 miles street use
+11
QtrWarrior
466cj
kim
butterbean
mgawat
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 460 engine failure 800 miles street use
Problem with these threads is all the important information needs to be pulled out of the poster. Wastes a lot of time and of course the OP gets annoyed.
Now that we established the head gasket was on right looking at the big burn out between 7 & 8 would say is safe that the spark plug wires were touching and was cross talk. Is easy enough to verify. Look at the wires for any burn marks. Failure started at 7 & 8 and was just progressing to 5 IMO.
They sell adjustable fuel pressure regulators that bolt to the stock fuel rail. Running a 30# injector on something calibrated for a 24# injector will not work. That is a 20% increase in fuel. Engine must have been pig rich.
466cj- Posts : 391
mgawat wrote:how does an adjustable fuel regulator get mounted to a triangle plate as comes with an oem fuel regulator?
Three bolts
D. Sea- Posts : 2768
the aftermarket adjustable fuel regulators I've seen come with a nipple not a plate and I can't see where there is any nipple associated with the OEM ones. Also;.l 7 and 8 spark plug wires were completely seperated and have no burn marks on them.
mgawat- Posts : 72
I melted up a sbc head and burnt the gasket EXACTLY how you did years ago as a novice on an aggressive NOS tune. Car was pulling like f__k before it no pulled no more. lol. Lean and too much advance as was previously said. Good luck with the reassembly.
4thHorseman- Posts : 400
cylinder look number 8
The other head was ready to let go also and rods showed predotanation signs on the bearings...Pretty much convinced faulty ECM did this
mgawat- Posts : 72
mgawat wrote:the aftermarket adjustable fuel regulators I've seen come with a nipple not a plate and I can't see where there is any nipple associated with the OEM ones. Also;.l 7 and 8 spark plug wires were completely seperated and have no burn marks on them.
Then you haven't seen enough of them. I know that BBK sells one and there are others.
One of these?
68galaxie- Posts : 349
thank you...what is the manufacturer and number ?
mgawat- Posts : 72
Lastly, How does one install a fuel gauge into the stock fuel rail circa 1995 7.5?
mgawat- Posts : 72
Most simply use the shrader valve on the fuel rail. Otherwise you have to put a T in the delivery side before the fuel rail, wich involves cutting the stock braided steel Teflon lined fuel line. Using AN adapters and a T and then another AN adapter to factory rail.
kim- Posts : 700
mgawat- Posts : 72
mgawat wrote:thank you...what is the manufacturer and number ?
http://www.kirbanperformance.com/product/776/Mustang+BILLET+ALUMINUM+ADJUSTABLE+FUEL+PRESSURE+REGULATOR+%235005.html
thank you...part ordered. I appreciate the help...especially when some folks just want to give attitudes.
mgawat- Posts : 72
Problem isn't the fuel pressure regulator. EFI is going to use the O2 output and cut injector pulse to keep it at 13-1 or as close as it can. Adjustable pressure regulators are very bad crutches for people who don't buy a large enough injector. 38 psi is common ford base fuel pressure, no vacuum. When you hook up vacuum then the pressure feed will reduce at idle and ramp back up to 38 psi at WOT or low vacuum
kim- Posts : 700
Page 2 of 2 • 1, 2
» oil temps in a street engine
» Engine Masters 414" stroker 351W street/strip engine
» Dyno Engine Failure Video
» 900-950 hp on street engine naturally aspirated????
» PLEASE POST PICS OF YOUR ENGINES !!
Page 2 of 2
