SOLD SOLD SOLD PLEASE DELETE
Post  Tony M on December 9th 2014, 3:13 pm
Car was rolled over at ATCO raceway. http://www.davemilcarek.com/101814/ page 22 is link to photo sequence. Car needs steel roof and quarters fixed. Hairy glass front end and driver's door replaced. left side header collector needs repair. I would recommend replacing every heim joint on chassis. Chromolly Chassis certified to 6.0, Weld 16x16 Bead locks, Weld spindle mount fronts, MSD, ARC N20 control box, Hurst pistol grip shifter, 16V battery, Mega 450 delay box, Digiset timers, RJ dual bottle mount, Lokar in car battery cut off, Wired for 3 N20 systems including bang and over ride buttons, Auto Meter data logger with 8 egts, N20 pressure, main fuel(before regulator)fuel, oil pressure sensors, vacuum and drive shaft sensors. MSD gauges. Griffin aluminum radiator. NEW strange double adjustable struts and Koni double adjustable shocks both built by Chris bell at Kinetics. Stroud fire system, MW 40 spline axels. PST aluminum drive shaft, NEW wishbone,4 Link bars, 72inch wheelie bars, MW aluminum center with alum pinion support and MW spool and 4:10 pro gears. 2 Stroud spring launcher parachutes NEW in 2011. Set up for BBF and PG. Car was just professionally wired using all Weathertite connectors. All new powder coated interior panels. Chassis was completely stripped and repainted with etching primer and metallic grey paint. Car is located in NE Pa. Best ET 6.85 @ 203.Photos will be emailed upon request. 10,000.00  Call Tony Morell 570-335- 6107 My phone sucks so leave a msg if I don't answer.
Tony M
Tony M
Re: SOLD SOLD SOLD PLEASE DELETE
Post  curleysracecars on December 10th 2014, 10:14 pm
This looks like a hell of a deal for someone. I could list 3-4 items that are worth more than the asking price. If it was closer, Id look at it.
curleysracecars
curleysracecars
View user profile http://www.curleysracecars.com
Post  cool40 on December 10th 2014, 11:07 pm
X2!!! You won't even start that chassis for the $$
Post  Tony M on December 12th 2014, 3:34 pm
Thanks Guys. I'm surprised no one requested the photos even if for no other reason to see the carnage. LOL
Tony M
Tony M
Post  dfree383 on December 13th 2014, 2:52 am
Pics please..... bounce
Post  Tony M on December 13th 2014, 9:01 pm
Send me your email address and I will send the photos.
Tony M
Tony M
