Let's play guess the hp & Trq
+12
gmsmkr
68galaxie
nitrous.f
jones
16 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Let's play guess the hp & Trq
jones wrote:Now I just have to find a rental truck for this weekend and go pick it up so I can get started with the swap.
Probably cheaper to ship it if you have to rent a truck.
Very nice build!
Exceeded my "guess" by 18 HP, well done!!
68galaxie- Posts : 349
I think this one is Impressive https://www.429-460.com/t4799p60-my-build-my-fox-transformation-lotsa-pics
the Coug- Posts : 3055
We talked about how easy it would be down the road to pull more power out of the engine. Simply swapping the pistons over for more compression and camshaft over to something more aggressive with race gas.
jones- Posts : 2230
the Coug wrote:I think this one is Impressive https://www.429-460.com/t4799p60-my-build-my-fox-transformation-lotsa-pics
I don't think that is a pump gas engine. It looked like he was running 110 on the dyno sheet & 13:1, I could have read it wrong. Cylinder head flow numbers are very similar, I believe mine got into the high 380's at .600 .650
jones- Posts : 2230
Ok, I have copied the SCJ flow bench numbers. These where flowed by the Kentucky crew.
SCJ Flow numbers
.200/I154/E103
.300/I234/E141
.400/I313/E175
.450/I346/E
.500/I371/E203
.550/I382/E215
.600/I386/E228
.650/I372/E236
.700/I370/E243
.750/I373/E247
.800/I373/E248
SCJ Flow numbers
.200/I154/E103
.300/I234/E141
.400/I313/E175
.450/I346/E
.500/I371/E203
.550/I382/E215
.600/I386/E228
.650/I372/E236
.700/I370/E243
.750/I373/E247
.800/I373/E248
jones- Posts : 2230
Very decent flow numbers.
I certainly like the .400" to .600" numbers.
The heads were certainly ported for fantastic mid lift numbers. 371 cfm @ .500" is awesome.
It certainly shows up on the dyno sheet too!
Jonsey, you got a killer pump gas deal there, don't change anything on it. You will be lucky if you can keep the driveline in that heifer.................
Congrats dude, massive ! ! ! ! !
I just wanted to say thank you to everyone that made this engine possible. Lem Evans for parts and Kentucky handler, Phillip Oakley for the awesome port work on the cylinder heads and Bob for assembly and dyno.
3/22/2015 I just got home with the engine and really had a good time visiting everyone while I was in Owensboro. Thank you to everyone that took time out of their day to chat it up with me!
jones- Posts : 2230
» Lets play the guess the hp
» Lets play spot the piperack lol
» lets compare intakes!
» Lets get this straight!!!
» N/A Low 5's doable Yes or No Lets Hear It
Page 3 of 3
