1st BBF Fox in Russia
+9
gmsmkr
Mustang-junky
butterbean
norg
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Re: 1st BBF Fox in Russia
Hey Norg, get you some Ford blue paint for the engine brother. and keep up the good work.
Thanks guys!
got 2 paint blue ford
and little beat more...
as i said - I an american iron
daily rig (traded for YJ dana 60 5.2l swaped) - hope this is my last german car...
norg- Posts : 55
Nice plate!
So sir's, some work is done:
Installed - rear end, body spacers 1.5", new pushrods, wheels, steering gear. Removed a stock tank and lots of dust.
At this time i have trying to start the motor but have no arc on a sparks.
I can't figuring out how the wiring should be connected. The ECU from 2.3l engine + Stock 1994 truck aftermarket distributor and coil.
The distributor has 8 pin connector = 1 red, 2 green, 4 black (absolutely different comparing with wiring diagram)
The coil has 2 pin connector = 1 RED/LT GRN (PWR +) and 1 TAN/YEL (coil -)
Found in engine compartment lots of cables = PIP, SPOUT, IGN GROUND, PWR, GRND...
Tried connecting each other but still no run.
Does anybody know - what should be connected to distributor?
Thanks!
Thanks!
norg- Posts : 55
damn awesome build , glad to have you here on the site !!!!
Just relax Norg, someone will chime in and help you on the factory stuff, I'm not very good with the wiring end of the builds but if it was mine I would install a pro comp dist and straight wire it and be done with it, but I know your parts are limited so just hang on, it looks like its going together pretty well so far.
butterbean- Posts : 676
Thanks bruno!bruno wrote:damn awesome build , glad to have you here on the site !!!!
norg- Posts : 55
Thank you!butterbean wrote:Just relax Norg, someone will chime in and help you on the factory stuff, I'm not very good with the wiring end of the builds but if it was mine I would install a pro comp dist and straight wire it and be done with it, but I know your parts are limited so just hang on, it looks like its going together pretty well so far.
I'm also hate the electrical work )
Prefer to go to simple way - to do a manual interruptor or something like that.
norg- Posts : 55
Norg..what you have is a 8 pin remote TFI distributor so with that said it only needs 3 wires to run.
Hold the plug with the lock up top
1) +12v in run
2) gnd
3)TFI gnd
4) PIP to TFI
5)no hook up
6)gnd
7)EEC gnd
8)PIP to EEC
Pin layout
1 top left. So it will go. 1234
5678
Hook 1 to 12v run power and coil positive
Hook 2 to gnd
Hook 6 to coil gnd
1) +12v in run
2) gnd
3)TFI gnd
4) PIP to TFI
5)no hook up
6)gnd
7)EEC gnd
8)PIP to EEC
Pin layout
5678
Hook 2 to gnd
Hook 6 to coil gnd
gmsmkr- Posts : 1364
Thank you very much!gmsmkr wrote:Norg..what you have is a 8 pin remote TFI distributor so with that said it only needs 3 wires to run.
1) +12v in run
2) gnd
3)TFI gnd
4) PIP to TFI
5)no hook up
6)gnd
7)EEC gnd
8)PIP to EEC
Pin layout
5678
Hook 2 to gnd
Hook 6 to coil gnd
I will go in that way.
norg- Posts : 55
see even a guy from Alabama can help at times LOL!!!!!!!!
Still no arc (norg wrote:Thank you very much!gmsmkr wrote:Norg..what you have is a 8 pin remote TFI distributor so with that said it only needs 3 wires to run.
1) +12v in run
2) gnd
3)TFI gnd
4) PIP to TFI
5)no hook up
6)gnd
7)EEC gnd
8)PIP to EEC
Pin layout
5678
Hook 2 to gnd
Hook 6 to coil gnd
hall sensor to be connected carefully
There are 4 wire to hall sensor RED, GRN, GRN, BLK
norg- Posts : 55
You can't run it by the 4cyl comp it has to be a stand alone deal .... hook 1 to switch power and make sure it has power when motor is turning over.
Here is a way to wire a duraspark distributor with a gm hei mod...... if you can't get the 8 pin dis to work is much simpler
You are absolutely right! Thank you cowboy!gmsmkr wrote:Here is a way to wire a duraspark distributor with a gm hei mod...... if you can't get the 8 pin dis to work is much simpler
Temporary I have bought here local the HEI module from LADA
Aaand is RUN It was just 1 second, but cool )
norg- Posts : 55
Sure glad you got it going your way
Nice build, you are doing an awesome job.
Jetman- Posts : 36
Jetman wrote:Nice build, you are doing an awesome job.
Thanks Jetman!
Work is ongoing (just pics):
norg- Posts : 55
is that a make shift gas can on top of the hood of the car? Classic!
blown86hallet- Posts : 1012
looking great !!!! time to do a burnout....
blown86hallet wrote: is that a make shift gas can on top of the hood of the car? Classic!
If you rotate that bottle 180* it'll feed under acceleration.
maverick- BBF CONTRIBUTOR
Yes sir it's classicblown86hallet wrote: is that a make shift gas can on top of the hood of the car? Classic!
But the holley blue already installed with new tank. The pump made in china and it's leaking.
norg- Posts : 55
Tried to do that brunobruno wrote:looking great !!!! time to do a burnout....
No rear brake yet. Can't go slow
But i hate the exhaust sound on it. The stock GT mufflers and 2" pipe there.
I love how it sound on a truck
norg- Posts : 55
looks like a Russian RED NECK!!!!!!
Hello Gentleman,
So, got one more trouble with the engine.
The intake lifters and cams lobes are destroyed fully.
The exhaust as new.
The damages is different for all 8 pcs, some has a dish, some lightly grinded, some grinded alot 4-5 mm, and one as new.
Scorpions 1.73 rockers half ok, half has damaged bearing.
Did not open the heads yet, but looks like the intake valve catched the pistons on 5 degree ATDC.
Did a lot of measurements at this time for intake valve - and for all the way (+10 -10 degrees both side of the TDC) and no clashing, even have a gap min 4 mm. But it's not true due lobe destroyed.
The valve lift for exhaust - 14,3 mm (0,565") as per specs, for intake valve lift 8 mm (0,314") destroyed.
The springs, pushrods is ok.
Cam xe274h, dove-c, dual springs, stock pistons, rods and crank (truck '94).
What kind of the piston recommended in this case?
Have another cam in the garage - dual energy 275DEH, 275/285, @219/232. 0,515/0,541, 110.
As reason also:
1- the rockers wrong adjustment. But i could be wrong with the exhaust adjustment, but it's ok.
2- the internal spring clashing of coils, but visually there are a gap 2 mm. (measured the exhaust lift).
The exhaust as new.
As reason also:
norg- Posts : 55
Page 1 of 2 • 1, 2
Page 1 of 2
