WTS/WTT SVO 9.200 aluminum block 2.75 mains 4.125 bore
2500.00. Excellent shape. No damage. Cylinders true. Crosshatch still there. Backup engine. It was a 410c.i. Motor mount pads machined off. Weighs less than 100#.
Will trade for BBF/Cleveland parts.
Located in Middle Tennessee.
738drvr- Posts : 600
Re: WTS/WTT SVO 9.200 aluminum block 2.75 mains 4.125 bore
What kind of stuff you need?
Killer Cleveland long block or killer set of BBF heads with matching intake(Kaase stuff preferred).
Lots of pictures if anyone wants to see it "up close". Pistons available also. It's a dry sump block. SVO Part number is M-6010-K351. Current bore is 4.130. Pistons are 4.125. Bore can be taken to 4.165. This one is good at 4.130. Lifter bores are .875. Standard cam bearings. No damage. No repairs. Would like to have a nice set of P-51's, SCJ's or A460's and an intake or ?
» SVO BLOCK 4.600 BORE
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» If you swap from iron block to aluminum block,,,
» block max. bore
» block max. bore
