Gas carb v/s Alky carb
Post  tconnection on February 25th 2015, 10:58 pm
What size alky carb would be equivalent to a 3 circuit 1350 qft carb?
tconnection
Re: Gas carb v/s Alky carb
Post  DanH on February 26th 2015, 4:37 am
tconnection wrote:What size alky carb would be equivalent to a 3 circuit 1350 qft carb?
whats more money 10 dimes or 1 dollar? 1350 or 1350?
thats my take on it. then there is the volume of the type fuel to air
DanH
Post  tconnection on February 26th 2015, 8:56 pm
Oh ok. I was thinking that if a engine was speced for a 1350 cfm gas carb that it would take a higher cfm alky carb due to the higher volume, to get in the same hp range.
tconnection
Post  richter69 on February 27th 2015, 12:17 am
fuel volume is more important w an alky carb, most times the cfm will be lower vs gas
Post  69F100 on February 27th 2015, 12:38 am
richter69 wrote:fuel volume is more important w an alky carb, most times the cfm will be lower vs gas
From what I have read on different sites on alky Like Jon said most seem to like less cfm for alky over gas. After I built my 552 I was going to sale my 1050 and step up to a 1150 or a toilet but after reading I decided to keep my 1050 and jetted it up to what APD said would be close and it works fine with my new setup.
Call APD 419-855-3073 and talk with them and see what size they recommend for your set.
Post  DanH on February 27th 2015, 3:42 am
your a believer then that a jet change make a carb bigger or smaller!
DanH
Post  dfree383 on February 27th 2015, 9:11 pm
He's saying volume of fuel, not air.
Post  sg86coupe on February 27th 2015, 11:11 pm
I tried a alky card once the same size as my gas, it was to much,
sg86coupe
