Valve clipping
Valve clipping
Post  10SHOTS on May 24th 2015, 4:00 pm
What is the minimum clearance that can be ran between the valves during overlap ? And what is the simplest way to gain clearance , can I turn each valve down .010 without causing some other problem
10SHOTS
10SHOTS
Re: Valve clipping
Post  supervel45 on May 24th 2015, 8:58 pm
Re: Valve clipping
Post  bbf-falcon on May 25th 2015, 6:50 am
I had a set of A429's that clipped.My machinist cut a little from just the intake valve and never any more problems.
